xabo Posted June 28, 2013 Share Posted June 28, 2013 What size water hose do you use......3/4" or 5/8" and why? Link to comment Share on other sites More sharing options...
0 Chewy Posted June 28, 2013 Share Posted June 28, 2013 I have both, but I use a 5/8's on the car. No reason... Just do! Check out Adams' hoses. Link to comment Share on other sites More sharing options...
0 xabo Posted June 28, 2013 Author Share Posted June 28, 2013 Do you find that you get more pressure/flow with the 5/8? Link to comment Share on other sites More sharing options...
0 Chewy Posted June 28, 2013 Share Posted June 28, 2013 I honestly have never noticed it. We have amazing water pressure in our house though. 3/4" should give you better flow. I think I prefer the 5/8" because it's a non kink and the 3/4 is rubber and kinks like MAAAAAAAAD! Link to comment Share on other sites More sharing options...
0 Rich B. Posted June 28, 2013 Share Posted June 28, 2013 Either would suffice as the nozzle itself is so downsized. I have a 3/8" copper line underground to the pool area for washing the filters and that has the same pressure as my 5/8" garden hoses, maybe better. The larger 3/4" diameter might be good if your running it 200' or so as Chewy mentions.... Link to comment Share on other sites More sharing options...
0 xabo Posted June 28, 2013 Author Share Posted June 28, 2013 It seems that when using the Fire hose type nozzle with the 5/8 hose, the stream is weak. Link to comment Share on other sites More sharing options...
0 Bunky Posted June 28, 2013 Share Posted June 28, 2013 (edited) My story: I installed a whole house water softener and it really impacted pressure and flow. I wash using a 1/2 faucet (meaning the feed line and faucet is 1/2-in). My pressure is not that bad (probably 60 psi+) but the GPM is barely 3 GPM. I had tried another fire hose nozzle and was disappointed but tried the Adam's nozzle was a significant improvement but I use a full flow shut off (like Adam's) and a 5/8-in hose and insure I have it fully puled out from the reel. It makes a difference although not dramatic. BTW, I did try the other hose nozzle in a higher flow/pressure situation and it works better but the Adam's nozzle worked best in all situations. I do plan to get the outside spigot (hose bib) upgraded to match the hose main feed (5/8-in) so that includes the feed line from to the lspigot to increase GPM. I have a 2.8 GPM pressure washer so I can tell when the feed is not keeping up with the output. The good news is that I have soft water and do not need to worry as much about water spots as I did earlier but I have still have mineral content so water spots do happen if not rinse in enough. I prefer the risk of dried soap over dried water so I only rinse a few ( 2 to 4) times during a wash. Edited June 28, 2013 by Bunky Link to comment Share on other sites More sharing options...
0 07RS4 Posted June 29, 2013 Share Posted June 29, 2013 3/4 Adam's...very noticeable difference in flow between the 5/8 and 3/4. Link to comment Share on other sites More sharing options...
0 LFairbanks Posted June 29, 2013 Share Posted June 29, 2013 Me personally if you don't have a 1 inch main water line and 3/4 line feeding your hose bib, go 5/8's. Most homes are going to be 3/4 main water line and 1/2 hose bib. Link to comment Share on other sites More sharing options...
0 Bunky Posted June 29, 2013 Share Posted June 29, 2013 Me personally if you don't have a 1 inch main water line and 3/4 line feeding your hose bib, go 5/8's. Most homes are going to be 3/4 main water line and 1/2 hose bib. From the houses I have seen, there is usually a 5/8 or 3/4-in runs and then faucets,etc are all 1/2-in runs from the main line to the faucet, shower, etc. In my case, the main feed ends in a T with one 1/2 run to the kitchen sink and other goes to the outside bib. The 1/2-run is at least 10 to 15 ft so plan to upgrade this so it is full size to the spigot and get the higher flow bib. The T itself is an insertion loss. wwaugaman 1 Link to comment Share on other sites More sharing options...
0 DaveVY Posted June 29, 2013 Share Posted June 29, 2013 I use 3/4", makes a noticeable difference for the Adams Fire Hose nozzle. But I have a 1" main and 3/4" pipe running to the outside faucet, and can fill a 5 gallon bucket is less than 40 seconds.. LFairbanks 1 Link to comment Share on other sites More sharing options...
0 EPHIOS Posted June 30, 2013 Share Posted June 30, 2013 I just bought a 5/8" Goodyear Commercial Hose (MADE IN U.S.A.). Men, this thing is super heavy and tough. You can tell that it's made really good. Link to comment Share on other sites More sharing options...
xabo
11 answers to this question
