GXPaycheck Posted May 7, 2015 Share Posted May 7, 2015 Starting a new thread rather than bumping up a really old one. What is recommended for maintaining the Flex? I remember something about oiling a felt pad? Link to comment Share on other sites More sharing options...
0 Kingsford Posted May 7, 2015 Share Posted May 7, 2015 (edited) Take the center bolt out with an allen wrench. Remove the backing plate. Use 3-IN-ONE Multi-Purpose Oil to lube the felt ring. I do it after every other use (2-Full Details) or after sitting a while. Don't drench the felt ring. A little oil goes a long way. The backing plate should be smooth where the felt ring comes in contact with it. If it is not smooth it should be replaced. http://www.3inone.com/products/multi-purpose/ Edited May 7, 2015 by Kingsford Link to comment Share on other sites More sharing options...
0 Sizzle Chest Posted May 7, 2015 Share Posted May 7, 2015 ^^^This is what I do! Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 7, 2015 Share Posted May 7, 2015 Every 30 hours +/- I recommend at least an inspection and cleaning. Remove the backing plate, inspect the backside of the backing plate, and the felt ring. Oil with 3 in 1 oil if necessary, just a few drops. Use compressed air to blow polish dust out of the housing and vents.Every few years I fully take the housing apart (very easy to do) and inspect where the cord connects inside the handle and the various components. The airflow does pull a fair amount of dust/debris inside so cleaning (again with compressed air) is all you need. spx1000 1 Link to comment Share on other sites More sharing options...
0 BitterGreg Posted May 7, 2015 Share Posted May 7, 2015 What about for Rupes? Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted May 7, 2015 Author Share Posted May 7, 2015 Thanx! Link to comment Share on other sites More sharing options...
0 LimitedDodge Posted May 7, 2015 Share Posted May 7, 2015 Good info. Looks like I will be taking mine apart tonight. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 7, 2015 Share Posted May 7, 2015 What about for Rupes? Similar, but I'd honestly recommend consulting your owners manual for recommended maintenance. Link to comment Share on other sites More sharing options...
GXPaycheck
