jpu471 Posted September 26, 2015 Share Posted September 26, 2015 Has anyone used the more permanent trim dye products as opposed to the dressings? Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted September 26, 2015 Share Posted September 26, 2015 If you are talking about trim coatings, some work well and some are garbage. How bad is the trim? Usually if the oxidation is removed with APC, and then dressed with VRT, after the first couple times its dressed you'll notice you can go longer between needing to dress, since the surface is protected and not allowed to oxidize. Link to comment Share on other sites More sharing options...
0 jpu471 Posted September 26, 2015 Author Share Posted September 26, 2015 Ive used Adams VRT,before it was super, and APC since 2009. Good results but I am looking for more permanent actual color coatings which then can be enhanced by VRT Link to comment Share on other sites More sharing options...
0 chops1sc Posted September 26, 2015 Share Posted September 26, 2015 PM sent Link to comment Share on other sites More sharing options...
jpu471
3 answers to this question
