crowvet Posted June 7, 2016 Share Posted June 7, 2016 My compressor is failing in my Goodman 1.5 ton Heat pump. Still blows warm, but barely cools when switching to A/C. I want to replace the outside unit,but my unit is a R22 unit. All the new ones seem to be R410 charged. The R22 units are dry charged. Should I just replace the whole system? Just the outside unit with a R22 unit, or Will a 410 unit work? Opinions welcome. Link to comment Share on other sites More sharing options...
LFairbanks Posted June 7, 2016 Share Posted June 7, 2016 (edited) If it were mine I would replace the coil and condenser, at the least with R-410A. You may want to evaluate the condition of your air handler (furnace) as well. R-22 was replaced with R-410A in 2010. I know the equipment is expensive. I replaced all of mine in 2007 and it cost me a little over 11K. I have a 4 ton Lennox unit. And a 110K btu furnace if I remember correctly. I'm sure prices have gone up since then too. I found the link below that may answer some of your questions. Hope that helps. http://www.ac-heatingconnect.com/whats-the-difference-between-r-22-and-r-410a/ Also wanted to mention when I switched mine over from R-22 to R-410A they had some way to clean the line set so that it didn't need replacing too. It was relatively new, and still works perfectly. HVAC is a sore subject with me. Edited June 7, 2016 by LFairbanks Link to comment Share on other sites More sharing options...
chas Posted June 7, 2016 Share Posted June 7, 2016 (edited) Chris is spot on. We will be facing a whole system replacement within 2 years, if not sooner, and I don't look forward to it. Edited June 7, 2016 by chas Link to comment Share on other sites More sharing options...
crowvet Posted June 8, 2016 Author Share Posted June 8, 2016 If it were mine I would replace the coil and condenser, at the least with R-410A. You may want to evaluate the condition of your air handler (furnace) as well. R-22 was replaced with R-410A in 2010. I know the equipment is expensive. I replaced all of mine in 2007 and it cost me a little over 11K. I have a 4 ton Lennox unit. And a 110K btu furnace if I remember correctly. I'm sure prices have gone up since then too. I found the link below that may answer some of your questions. Hope that helps. http://www.ac-heatingconnect.com/whats-the-difference-between-r-22-and-r-410a/ Also wanted to mention when I switched mine over from R-22 to R-410A they had some way to clean the line set so that it didn't need replacing too. It was relatively new, and still works perfectly. HVAC is a sore subject with me. Thanks Chris, I lucked out. Turned out to be one of the auxiliary heat strips staying on. LFairbanks 1 Link to comment Share on other sites More sharing options...
LFairbanks Posted June 8, 2016 Share Posted June 8, 2016 Thanks Chris, I lucked out. Turned out to be one of the auxiliary heat strips staying on. Sounds like you found an honest company that didn't try to sell you a whole new system. In my experience that is highly unusual. Link to comment Share on other sites More sharing options...
crowvet Posted June 8, 2016 Author Share Posted June 8, 2016 Sounds like you found an honest company that didn't try to sell you a whole new system. In my experience that is highly unusual. The guy was GOOD, had me going in no time. So nice when you get the right guy. Link to comment Share on other sites More sharing options...
Rodger Posted June 9, 2016 Share Posted June 9, 2016 Gonna be a lot more expert tomorrow. New HP being installed. About $4800 bucks of smart as hell. Link to comment Share on other sites More sharing options...
