2quikta Posted July 2, 2016 Share Posted July 2, 2016 Is there a recommended car wash dilution? The instructions say to fill the bucket 2/3, but is there an actual recommended ratio? Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted July 2, 2016 Share Posted July 2, 2016 I believe it is 2/3 a bucket with one ounce of soap. It really doesn't take much. Link to comment Share on other sites More sharing options...
0 Ls1transam Posted July 2, 2016 Share Posted July 2, 2016 I've noticed some times there isn't as many soap suds. Even trying to use the same amount of soap. Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted July 2, 2016 Share Posted July 2, 2016 Never had that problem with Adams Car Wash, just put it on the mit and blast it with the hose. More bubbles than I know what to do with. Link to comment Share on other sites More sharing options...
0 mc2hill Posted July 3, 2016 Share Posted July 3, 2016 I use 1 oz. per 2 gallons of water, and get plenty of suds. Ricky Bobby 1 Link to comment Share on other sites More sharing options...
0 chops1sc Posted July 5, 2016 Share Posted July 5, 2016 I like to fill the bucket with water up to the grit guard then add 1-2 oz of soap. Then I use my pressure washer nozzle to get it nice and foamy. Halfway through the wash I hit it again with the pressure washer if needed. Suds for days! Link to comment Share on other sites More sharing options...
0 rrmccabe Posted July 5, 2016 Share Posted July 5, 2016 I honestly do whatever I can to slow the foam down or its hard to get bucket fill without it running over. Is there any reall advantage to foam when applying with a mitt? Just well mixed so you have good lubricity?? Link to comment Share on other sites More sharing options...
0 chops1sc Posted July 5, 2016 Share Posted July 5, 2016 I honestly do whatever I can to slow the foam down or its hard to get bucket fill without it running over. Is there any reall advantage to foam when applying with a mitt? Just well mixed so you have good lubricity?? That's why I pre-fill the bucket with at least one gallon before adding soap. By the time I'm done I usually have about 1-2" of water above the grit guard. Link to comment Share on other sites More sharing options...
0 flyboy9994 Posted July 6, 2016 Share Posted July 6, 2016 I always use too much soap if there is such a thing. I just fill the bucket half way (3 gallon bucket), squirt in probably about 2 ounces, then rip up the suds with a full blast from a hose sprayer. When the foam reaches the top of the bucket, I'm done. Too much soap? Probably but it works great for me. Link to comment Share on other sites More sharing options...
0 chops1sc Posted July 6, 2016 Share Posted July 6, 2016 I think it's only too much soap when you get to the bottom of your bottle and need to reorder, lol! chupr0kabra 1 Link to comment Share on other sites More sharing options...
2quikta
9 answers to this question
