hemi1300 Posted August 6, 2016 Share Posted August 6, 2016 My 2014 ram I just bought has the cooled perforated leather seats and a few small spots where the pores look clogged with something. Any good way to go about removing the crud? Link to comment Share on other sites More sharing options...
0 PT3 Posted August 7, 2016 Share Posted August 7, 2016 My 2014 ram I just bought has the cooled perforated leather seats and a few small spots where the pores look clogged with something. Any good way to go about removing the crud? I use tooth picks Link to comment Share on other sites More sharing options...
0 Odds and Ends Posted August 7, 2016 Share Posted August 7, 2016 Depending on the size of the holes, pipe cleaners will work, plastic dental pick type tools, and yes, in a pinch, toothpicks will work. Anything that is small and sharp enough to get in the holes is also capable of causing damage so whatever your weapon of choice ends up being, proceed with caution. - Darryl Link to comment Share on other sites More sharing options...
0 TheWolf Posted August 7, 2016 Share Posted August 7, 2016 I used the vacuum first, without any attachment. Just put the end of the hose right on the leather to try and suck out the crud. For stubborn clogs, I use a plastic pick that has a rounded tip, so it is not as sharp as a toothpick. Less likely to cause damage. Tipton Polymer Cleaning Picks https://www.amazon.com/dp/B0048KGFHU/ref=cm_sw_r_cp_apa_TfQPxbJ1C29G4 Link to comment Share on other sites More sharing options...
0 HydroBlueJK Posted August 7, 2016 Share Posted August 7, 2016 Air Link to comment Share on other sites More sharing options...
0 hemi1300 Posted August 8, 2016 Author Share Posted August 8, 2016 If using a small pick, are u guys somehow able to pry the piece of crud out of the hole or do u just push it down further to clear the pores, if that makes sense Link to comment Share on other sites More sharing options...
hemi1300
5 answers to this question
