ticaaal70 Posted November 24, 2016 Share Posted November 24, 2016 I need some advice on how to remove these stains. I dont have a water extractor. I do have alot of Adams products though. Is there some combination of products I can use to remove them? Thanks in advance! Link to comment Share on other sites More sharing options...
0 shane@detailedreflections Posted November 24, 2016 Share Posted November 24, 2016 A steamer is your friend with stains like these. I use a McCollough 1385. It's got an attachment with a brush on it that will really help to mobilize these stains. Short of that, you can use carpet and upholstery cleaner and a stiff bristle brush to agitate it loose. I don't know if you'll get it all the way out that way. My routine would be to steam and scrub with carpet and upholstery cleaner, then to use a hot water extractor. PHOKUS 1 Link to comment Share on other sites More sharing options...
0 Odds and Ends Posted November 26, 2016 Share Posted November 26, 2016 Adams Carpet and Upholstery cleaner will work magic on those! You'll be blown away. BUT, I have some bad news in the pink/red stuff. Doubt there is anything short of genuine magic on those. Red dye is practically impossible. You may have to go after it multiple times, but the before and after should be quite drastic. Link to comment Share on other sites More sharing options...
0 PHOKUS Posted November 26, 2016 Share Posted November 26, 2016 (edited) Spray Dye is what you're looking for. Thoroughly clean the carpet. Preferably with a steam cleaner and remove as much of the offending stain as possible. Spray the dye on and work it in with your fingers (latex gloves are handy here). Using a hair dryer or a heat gun set on low, dry the dyed areas while working the fabric with your gloved fingers. Finally, let it sit for 8 hours or so, then clean it again with upholstery cleaner and warm water. Use a junk towel to wipe the residue.. Edited November 26, 2016 by PHOKUS PacificNWBuckeye 1 Link to comment Share on other sites More sharing options...
ticaaal70
Thanks in advance!
3 answers to this question
