joelilton23 Posted January 23, 2017 Share Posted January 23, 2017 Hey Guys, Just picked up a titanium exhaust for my car, and its looking a little neglected. I want to give it a hit with some metal polish to bring back some shine - Will Metal Polish #1 and #2 be safe to use on it? Thanks! Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted January 23, 2017 Share Posted January 23, 2017 Hi Joel, Do you have any pictures of the exhaust? Does it have a 'burnt tip' finish like some aftermarket titanium exhausts? If it does have a burnt tip finish, you do not want to use any metal polish on it. If you want a clean finish or to polish to a mirror shine, Metal Polish #1 and #2 should work no problem. As always, test in a small spot first just to make sure, preferably on the underside of the exhaust tip where it will not be as noticeable if there are any irregular reactions (you should be fine though). joelilton23 1 Link to comment Share on other sites More sharing options...
0 joelilton23 Posted January 23, 2017 Author Share Posted January 23, 2017 Hi Joel, Do you have any pictures of the exhaust? Does it have a 'burnt tip' finish like some aftermarket titanium exhausts? If it does have a burnt tip finish, you do not want to use any metal polish on it. If you want a clean finish or to polish to a mirror shine, Metal Polish #1 and #2 should work no problem. As always, test in a small spot first just to make sure, preferably on the underside of the exhaust tip where it will not be as noticeable if there are any irregular reactions (you should be fine though). Hey Dan, Thanks for the reply. When I first got it, it was just the normal silver, but the tip has started to turn blue due to the heat. I might just polish the barrel of it, and leave the tip the blue colour. Thanks! Link to comment Share on other sites More sharing options...
joelilton23
Hey Guys,
Thanks!
2 answers to this question
