Nathan Posted February 25, 2017 Share Posted February 25, 2017 Has anyone every used rinseless wash as a clay lube? Not diluted, just after you rinseless wash the car instead of drying it, clayinf and then drying? Link to comment Share on other sites More sharing options...
0 falcaineer Posted February 26, 2017 Share Posted February 26, 2017 (edited) Some food for thought on your question...in the Adam's Daily Driver wash video, Adam rinses the car completely after a regular wash, leaves it wet, then adds DS for additional lubrication to clay. I've never tried what you're proposing, but it seems to me the same principle could be said for Rinseless and leaving the car wet, while also using DS. Here's the link, and it's at the ~10:40 mark when he talks about the different approach for his daily: Edited February 26, 2017 by falcaineer Nathan 1 Link to comment Share on other sites More sharing options...
0 Ls1transam Posted February 25, 2017 Share Posted February 25, 2017 I think it's recommend to do a 6:1 dilution for the Rinseless. But I have clayed after washing before drying the vehicle off. Works good and saves a step. Just helps if you're in a garage or shade. Link to comment Share on other sites More sharing options...
0 stripesace Posted February 25, 2017 Share Posted February 25, 2017 Ive used it all the way down to 32:1 PLENTY slick for clay lube. Link to comment Share on other sites More sharing options...
0 chops1sc Posted February 25, 2017 Share Posted February 25, 2017 (edited) I thought it was even more than that. Like 1:256?? CORRECTION 1:64 for clay lube Edited February 25, 2017 by chops1sc Link to comment Share on other sites More sharing options...
0 Nathan Posted February 26, 2017 Author Share Posted February 26, 2017 But is it safe to just do t after rinseless wash? Or not recommended? galaxy 1 Link to comment Share on other sites More sharing options...
0 chops1sc Posted February 27, 2017 Share Posted February 27, 2017 I leave the vehicle wet while claying. I always hose off the iron decontaminant and I don't want to waste a drying towel. Link to comment Share on other sites More sharing options...
0 stingrayc7 Posted February 28, 2017 Share Posted February 28, 2017 64:1 for clay lube Link to comment Share on other sites More sharing options...
0 galaxy Posted February 28, 2017 Share Posted February 28, 2017 But is it safe to just do t after rinseless wash? Or not recommended? I say not safe at all. With a rinseless wash, you're using 2oz's or so to three gallons of water. Haven't done the math on that dilution ratio, but not near enough. Having done a few rinseless washes at this mixture, not only is there not enough water left on the vehicle, but that ratio of what's left is no where near slick enough IMO. I'd never do it on mine. What I would consider however is if you are claying right away, there's no need to dry. Rinseless wash, leave whatever water is on the car, then clay using your preferred products as usual. Me, I'm using a QD. Link to comment Share on other sites More sharing options...
0 chops1sc Posted February 28, 2017 Share Posted February 28, 2017 I say not safe at all. With a rinseless wash, you're using 2oz's or so to three gallons of water. Haven't done the math on that dilution ratio, but not near enough. Having done a few rinseless washes at this mixture, not only is there not enough water left on the vehicle, but that ratio of what's left is no where near slick enough IMO. I'd never do it on mine. What I would consider however is if you are claying right away, there's no need to dry. Rinseless wash, leave whatever water is on the car, then clay using your preferred products as usual. Me, I'm using a QD. I think he means is it safe to clay with proper lube? If so then you can definitely clay after a rinseless wash. If he means can he use the leftover water from the wash itself, then no. You need some type of lubricant. Link to comment Share on other sites More sharing options...
0 galaxy Posted February 28, 2017 Share Posted February 28, 2017 I think he means is it safe to clay with proper lube? If so then you can definitely clay after a rinseless wash. If he means can he use the leftover water from the wash itself, then no. You need some type of lubricant. Yea Chris, this is what I was trying to say as well...agreed. Link to comment Share on other sites More sharing options...
Nathan
10 answers to this question
