Abelm13 Posted July 21, 2018 Share Posted July 21, 2018 I'll be doing a paint correction, It's my first time and have questions on the order Strip wash car Clay bar entire car Correcting polish Finishing polish Wipe down residue with Coating prep Apply Paint sealant Brilliant Glaze Americana Wax My question is if wiping down the car with coating prep is necessary or do I just apply the Paint Sealant? Any other suggestions? Link to comment Share on other sites More sharing options...
0 cwp2016nd Posted July 21, 2018 Share Posted July 21, 2018 (edited) I’m sure many will tell you it’s not necessary, but I think it’s a good idea. Every time I’m done polishing a vehicle i give it a wipe down with wax and grease remover, because the sealant will have a completely bare surface to adhere to. Edited July 21, 2018 by cwp2016nd pirahnah3 and Thorsager 2 Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted July 21, 2018 Share Posted July 21, 2018 If you are going to spend this amount of time, do a decon with iron remover, its amazing how much metal stuff is in your paint that it removes, this I typically do before clay to make for less junk to remove. Also as for a wipe down, you can use the prep, but you can also use a mix of iso Alcohol. There is also a LONG running debate (And this thread is not for it) about putting Glaze under the paint sealant, Glaze has some filling properties and can really fill in tiny imperfections before you really seal it in, thou as others would point out it puts a layer between the paint sealant and the paint that will make the bond not as strong. I personally would glaze OVER the Americana not under it. The Glaze will add a really awesome pop on the car but wont last that long. Under the Americana it will offer some nice finish but you will not get that pop from it. Link to comment Share on other sites More sharing options...
0 BHarris23 Posted July 22, 2018 Share Posted July 22, 2018 18 hours ago, Abelm13 said: I'll be doing a paint correction, It's my first time and have questions on the order Strip wash car Clay bar entire car Correcting polish Finishing polish Wipe down residue with Coating prep Apply Paint sealant Brilliant Glaze Americana Wax My question is if wiping down the car with coating prep is necessary or do I just apply the Paint Sealant? Any other suggestions? Here are the steps I would do (different for everyone though): -Car shampoo with APC added (same effect as Strip Wash) -Iron Decon -Clay using soap from Car Shampoo -Polish (do a test panel with finish polish to see if that will take out imperfections first. If it doesn’t, move down to cutting) -50/50 Iso or Coating Prep (they do basically the same thing) -Paint Sealant, if you’re not doing a ceramic coating -Wax -Optional: Glaze Glaze to me doesn’t go under sealant or anything else. You either use it stand alone or over everything. It doesn’t have a very long lifespan and therefore, should go on top. The longest spanning product goes on bottom. (Metal-paint-clear coat-clear bra-ceramic coating-sealant-wax-glaze) Link to comment Share on other sites More sharing options...
0 shane@detailedreflections Posted July 22, 2018 Share Posted July 22, 2018 1 hour ago, BHarris23 said: Here are the steps I would do (different for everyone though): -Car shampoo with APC added (same effect as Strip Wash) -Iron Decon -Clay using soap from Car Shampoo -Polish (do a test panel with finish polish to see if that will take out imperfections first. If it doesn’t, move down to cutting) -50/50 Iso or Coating Prep (they do basically the same thing) -Paint Sealant, if you’re not doing a ceramic coating -Wax -Optional: Glaze Glaze to me doesn’t go under sealant or anything else. You either use it stand alone or over everything. It doesn’t have a very long lifespan and therefore, should go on top. The longest spanning product goes on bottom. (Metal-paint-clear coat-clear bra-ceramic coating-sealant-wax-glaze) I agree with most of what you said. The changes I would make would be to skip the IPA wipedown. We have had no longevity issues when applying sealant without a wipedown provided that you buff appropriately after polishing. I suppose if you wanted to double check yourself, it’s an okay way to go. It mostly just takes up time in my opinion. We go sealant, glaze and wax. Sealant to bare paint. Glaze over it. And wax on top. By coating it with wax, you get slightly better durability out of it. Although it’s still a short lifespan product. Link to comment Share on other sites More sharing options...
0 BHarris23 Posted July 22, 2018 Share Posted July 22, 2018 1 hour ago, shane@detailedreflections said: I agree with most of what you said. The changes I would make would be to skip the IPA wipedown. We have had no longevity issues when applying sealant without a wipedown provided that you buff appropriately after polishing. I suppose if you wanted to double check yourself, it’s an okay way to go. It mostly just takes up time in my opinion. We go sealant, glaze and wax. Sealant to bare paint. Glaze over it. And wax on top. By coating it with wax, you get slightly better durability out of it. Although it’s still a short lifespan product. I like to use an IPA after polishing simply to make sure there are no lingering oils. Depending on what polish and how much is used, I’ve found some oils are leftover. Again, not every polish or compound but some. Link to comment Share on other sites More sharing options...
Abelm13
Strip wash car
Clay bar entire car
Correcting polish
Finishing polish
Apply Paint sealant
Brilliant Glaze
Americana Wax
5 answers to this question
