I’ve asked several question and got answers when I needed them and every single person on here has been amazing!
Anyway. I’ve seen a ton of answers about preparing to ceramic spray a car and claying beforehand.
However, Not knowing what kind of coating has been applied beforehand, I want to clay bar and use APC or IR. Will the clay remove or damage a ceramic coating?
As I stated in my new member post, I have a new to me 2017 CHEVROLET SS. When I bought it, it had 18k miles. It has some sort of coating on it. I have no idea what kind. It beads up pretty good still. But I can feel a tiny, tiny amount of contamination on the hood. Nothing pretty much on the roof or trunk. But I also have quite a few spots on the door and rocker panels of that iron dots and a little bit of tar dots. None of these are major but enough to annoy me.
If it’s simply waxed, I understand the clay and chemicals will strip the coating. Which I want to CSC anyways But will I be damaging the coating if indeed it was ceramic coated? I’m kinda thinking it was either waxed or sealed because there is 1 spot on a piece of trim that is discolored white. And I’m thinking a ceramic coated car shouldn’t have iron spots or tar stick to it?
My initial assumption is that if I clay and decontaminate, It won’t matter what was under it in the first place because no matter what, I’ll be recoating with ceramic anyways. I’ll either be putting a new coat on or just added an additional layer.
Pugsly14
3 answers to this question
