I recently applied the graphene coating to my vehicle after getting it to virgin clear coat. But I didn't see any rainbow effect after applying on the pearl white paint, even waiting 5 minutes, so I wiped/leveled off the excess and started wiping after a minute or two figuring I could go over it with a second coat if needed. The directions don't give a time estimate for flashing, and since this was my first DIY coating I was less than comfortable with the "wait for the rainbow" instructions. The panel I started with has visible high spots if it catches the sun at the right angle and I will have to polish it down. Will hand applicator be good enough for the polish or will i need a mechanical polisher? Also a time estimate, even if a wide range, would be very helpful on the instructions in case rainbowing isn't occurring. I applied this inside a garage with temps at about 60F using the UV light to ensure coverage, which the coating wasn't very much lighter than the paint itself. I imagine this process is a lot easier with a colored vehicle, any thoughts?
Tyler C
2 answers to this question
