Superdutytd Posted April 6, 2009 Share Posted April 6, 2009 While I was polishing and waxing my truck my PC started to get hot. The motor was getting pretty warm, I mean warm enough my hand started to get hot, anyone else ran into this problem? Link to comment Share on other sites More sharing options...
0 Team Adam's Posted April 6, 2009 Share Posted April 6, 2009 Mine never gets so hot that I feel discomfort - I do shut it down regularly though after doing a body panel just for my own comfort. I usually need to stand up and stretch! Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted April 6, 2009 Share Posted April 6, 2009 While I was polishing and waxing my truck my PC started to get hot. The motor was getting pretty warm, I mean warm enough my hand started to get hot, anyone else ran into this problem? YOU FORGOT TO INSTALL THE WASHER!!! There's a washer that goes on the shaft BEFORE you add the plate. If you don't install that washer, the counterweight will not spin and will burn up the polisher! Is the washer installed? Link to comment Share on other sites More sharing options...
0 Superdutytd Posted April 6, 2009 Author Share Posted April 6, 2009 Oh good thanks Junkman, probably also why it vibrates the crap out of me too? God I've polished my mustang and did the entire truck. I did let it cool a lot between body panels because I felt it getting warm. Oh well at least if it burns up I can get a replacement for a good price from one of our suppliers I don't have the polisher here with me but I'm pretty sure its not installed. Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted April 6, 2009 Share Posted April 6, 2009 Been there, done that :( Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted April 6, 2009 Share Posted April 6, 2009 Been there, done that :( I got lucky with mine an actually read the instructions before I started. I NEVER read the instructions! Link to comment Share on other sites More sharing options...
0 Sundog Detailing Posted April 6, 2009 Share Posted April 6, 2009 This may not apply to a PC but my Flex would get real hot and found that a larger gauge extention cord helped quite a bit, I now use a 10 gauge cord. Link to comment Share on other sites More sharing options...
0 Sizzle Chest Posted April 6, 2009 Share Posted April 6, 2009 YOU FORGOT TO INSTALL THE WASHER!!! There's a washer that goes on the shaft BEFORE you add the plate. If you don't install that washer, the counterweight will not spin and will burn up the polisher! Is the washer installed? HELP!! Where does this washer go? On the shaft underneath the backing plate? I don't think mine has one installed. If not, will any washer that fits the shaft diameter work? Thanks! Link to comment Share on other sites More sharing options...
0 Chewy Posted April 6, 2009 Share Posted April 6, 2009 I don't think I have the washer installed either... I'm not sure I even have one... Hmmm... Something to look at now... Mine gets hot and it vibrates like mad but hell it's a DA so I thought it was normal... Chris Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted April 6, 2009 Share Posted April 6, 2009 HELP!! Where does this washer go? On the shaft underneath the backing plate? I don't think mine has one installed. If not' date=' will any washer that fits the shaft diameter work? Thanks![/quote'] Do you still have the paperwork that came with the polisher? The washer is identified as part# 850218, item# 146. You can order it from DeWalt's Website. The washer does two things. It keeps the plate from rubbing against the polisher (which will heat that polisher up and overwork it to death), and it also gives you room to get the wrench in between the buffer and the backing plate so that you can change backing plates. Link to comment Share on other sites More sharing options...
0 6spdg37s Posted April 6, 2009 Share Posted April 6, 2009 uhh i need to check this oout as well..i used it twice so far..is taht enough to burn out the PC? i didnt have any heat problems with it Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted April 6, 2009 Share Posted April 6, 2009 uhh i need to check this oout as well..i used it twice so far..is taht enough to burn out the PC? i didnt have any heat problems with it Yea, it'll burn it up over time as heat and electronics and the worst of enemies. If yours is not getting hot then I would assume you have it put together correctly. The heat is the tell tell sign when there is a problem. Link to comment Share on other sites More sharing options...
0 Sizzle Chest Posted April 6, 2009 Share Posted April 6, 2009 Do you still have the paperwork that came with the polisher? The washer is identified as part# 850218, item# 146. You can order it from DeWalt's Website. The washer does two things. It keeps the plate from rubbing against the polisher (which will heat that polisher up and overwork it to death), and it also gives you room to get the wrench in between the buffer and the backing plate so that you can change backing plates. I need to check. Geez, I've had it for a few years now. I may have lost the washer during a backing plate swap out. I will check. Thanks for the info. Scott Link to comment Share on other sites More sharing options...
0 6spdg37s Posted April 6, 2009 Share Posted April 6, 2009 well maybe i jsut didnt overtighten it? id assume that thats one of the purposes of having the washer on there no? Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted April 6, 2009 Share Posted April 6, 2009 well maybe i jsut didnt overtighten it? id assume that thats one of the purposes of having the washer on there no? See post #10. Link to comment Share on other sites More sharing options...
0 jjwvette Posted April 6, 2009 Share Posted April 6, 2009 Great info AJ:thumbsup: Link to comment Share on other sites More sharing options...
0 6spdg37s Posted April 6, 2009 Share Posted April 6, 2009 Gotcha..thanks junkman Link to comment Share on other sites More sharing options...
0 Superdutytd Posted April 6, 2009 Author Share Posted April 6, 2009 I also use a large gauge cord, probably saved my poor little PC from dying Link to comment Share on other sites More sharing options...
0 chevyfreak06 Posted April 7, 2009 Share Posted April 7, 2009 What washer the the black one on the gen2 backing plate or the one that comes with the pc. I just use the black one on the gen2 backing plate, is this why mines gettin hot? Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted April 7, 2009 Share Posted April 7, 2009 What washer the the black one on the gen2 backing plate or the one that comes with the pc. I just use the black one on the gen2 backing plate, is this why mines gettin hot? I say that would be an affirmative, sir! Link to comment Share on other sites More sharing options...
0 chevyfreak06 Posted April 7, 2009 Share Posted April 7, 2009 should i use both washers? Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted April 7, 2009 Share Posted April 7, 2009 should i use both washers? Post a picture of what you have. Link to comment Share on other sites More sharing options...
0 chevyfreak06 Posted April 7, 2009 Share Posted April 7, 2009 theres that little washer that comes with the pc, and the black one thats on the gen2 backer. Mine gets hot and vibrates really bad, i just use the black one on the gen2 backer Link to comment Share on other sites More sharing options...
0 6spdg37s Posted April 7, 2009 Share Posted April 7, 2009 i jus put the washer on my Gen1 pads and it doesnt vibrate as bad anymore and feels much better given i havent tryed it on a car yet but still Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted April 7, 2009 Share Posted April 7, 2009 theres that little washer that comes with the pc, and the black one thats on the gen2 backer. Mine gets hot and vibrates really bad, i just use the black one on the gen2 backer try the one that came with the PC Link to comment Share on other sites More sharing options...
0 Superior Suds Posted April 7, 2009 Share Posted April 7, 2009 Can somebody post a picture of where this goes, or a picture procedure? I'm not sure if I have a washer, and it doesn't vibrate and doesn not get hot. Just want to make sure I am correct. Link to comment Share on other sites More sharing options...
Superdutytd
40 answers to this question
