Cyclone Posted May 1, 2009 Share Posted May 1, 2009 This was posted on another site, and it looks interesting... Can I get some professional opinions? http://www.drcolorchip.com/ Quote Link to comment Share on other sites More sharing options...
0 ozzy Posted May 1, 2009 Share Posted May 1, 2009 I tested this on my Intrepid, in the link below on page 1 has what I ordered, page 3 shows what I got in my order, page 4 shows some before and after shots, I was impressed by the results, plus it was only 60 dollars. Paint chip repair review Quote Link to comment Share on other sites More sharing options...
0 11chevz71 Posted May 1, 2009 Share Posted May 1, 2009 I tested this on my Intrepid, in the link below on page 1 has what I ordered, page 3 shows what I got in my order, page 4 shows some before and after shots, I was impressed by the results, plus it was only 60 dollars. Paint chip repair review what happens if you only need to one spot. I have been lookin at this also for a while because i cannot find my color in other product that are out there. Quote Link to comment Share on other sites More sharing options...
0 Marylander Posted May 1, 2009 Share Posted May 1, 2009 Ozzt, that looks great. I may have to try that stuff. Quote Link to comment Share on other sites More sharing options...
0 BrandonL Posted May 1, 2009 Share Posted May 1, 2009 .....hm.......I might have to get this for myself. I bought a paint pen for my WRX but I have a lot of chips and this would probably be a much better option. Thanks for the links Quote Link to comment Share on other sites More sharing options...
0 ozzy Posted May 1, 2009 Share Posted May 1, 2009 what happens if you only need to one spot. I have been lookin at this also for a while because i cannot find my color in other product that are out there. Well as I learned in the Army "It's better to have it and not need it, then need it and not have it" - it was only 60 dollars, I've spent more on worse. Also it goes a very long way, it may not look like it, but it does. Quote Link to comment Share on other sites More sharing options...
0 BrandonL Posted May 1, 2009 Share Posted May 1, 2009 Did you just do one coat or did you have to do the process multiple times? Quote Link to comment Share on other sites More sharing options...
0 ozzy Posted May 1, 2009 Share Posted May 1, 2009 Did you just do one coat or did you have to do the process multiple times? Nope, one coat did it for the hood, I had a bad scrape on the side and it did take 2 passes, I don't even notice it now. Quote Link to comment Share on other sites More sharing options...
0 JJ1o87 Posted May 1, 2009 Share Posted May 1, 2009 Tried it out last night on my car. Doesn't work! I first let the paint dry for 2 minutes as per instructions and the stuff came right off in step 2. Then I let dry for 5 minutes - same result. THEN, I tried letting it dry for an hour. It came right off again. I want my money back. Quote Link to comment Share on other sites More sharing options...
0 BrandonL Posted May 1, 2009 Share Posted May 1, 2009 Nope, one coat did it for the hood, I had a bad scrape on the side and it did take 2 passes, I don't even notice it now. You said that once you got the hang of it that it was easier. What did you do to make it easier to apply? This product really interests me Quote Link to comment Share on other sites More sharing options...
0 BrandonL Posted May 1, 2009 Share Posted May 1, 2009 Tried it out last night on my car. Doesn't work! I first let the paint dry for 2 minutes as per instructions and the stuff came right off in step 2. Then I let dry for 5 minutes - same result. THEN, I tried letting it dry for an hour. It came right off again. I want my money back. Just curious but did you remove any wax first? That could be a issue as far as it not staying on Quote Link to comment Share on other sites More sharing options...
0 JJ1o87 Posted May 1, 2009 Share Posted May 1, 2009 Just curious but did you remove any wax first? That could be a issue as far as it not staying on No, I was thinking of hitting it with rubbing alcohol - that good? Quote Link to comment Share on other sites More sharing options...
0 BrandonL Posted May 1, 2009 Share Posted May 1, 2009 Either that or some diluted APC will probably do the trick just fine. I don't know too much about paint touch up but I have heard from many people that in order to do it you need to strip off any wax that is in the area it's applied to. And if you are like the rest of us lunatics on this site you probably have a very fresh layer of wax on it right now I say strip off the wax and give it another shot Quote Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted May 1, 2009 Share Posted May 1, 2009 I would wash with Dawn first, clay, then 50/50 Alcohol mix, that should get just about anything off :D:D Quote Link to comment Share on other sites More sharing options...
0 JJ1o87 Posted May 1, 2009 Share Posted May 1, 2009 Either that or some diluted APC will probably do the trick just fine. I don't know too much about paint touch up but I have heard from many people that in order to do it you need to strip off any wax that is in the area it's applied to. And if you are like the rest of us lunatics on this site you probably have a very fresh layer of wax on it right now I say strip off the wax and give it another shot Lol clearly you didn't see my page long post about my twelve hour detail. So yeah very fresh wax on it. I will give that a shot - thanks bro! Quote Link to comment Share on other sites More sharing options...
0 jjwvette Posted May 1, 2009 Share Posted May 1, 2009 Guess I won't buy this:burnout:thanks for the info Quote Link to comment Share on other sites More sharing options...
0 ozzy Posted May 1, 2009 Share Posted May 1, 2009 Before I bought this product, I called them and asked a lot of questions, one of the first was the wax question, yes you need to remove any polish and wax prior to use, if you don't it will be sitting on top of the wax and won't stick to anything. Quote Link to comment Share on other sites More sharing options...
0 DenaliDan Posted May 2, 2009 Share Posted May 2, 2009 I bought and used that kit years ago. Did it work for me? Not bad. Let me put it this way: I haven't bought another one. I've done just as good a job with the manufacturer's touch-up paint, a toothpick, and a small hobby paint brush with most of the bristles cut out. But, hey, I'm no pro. Quote Link to comment Share on other sites More sharing options...
0 SpicyGTO Posted May 3, 2009 Share Posted May 3, 2009 I just tried out the Langka system and it works very well...I'm in the middle of fixing a pretty good sized chip on my hood (down to the sheet metal). I will post results after I'm done...but so far so good. Quote Link to comment Share on other sites More sharing options...
0 BlueSteel530i Posted May 8, 2009 Share Posted May 8, 2009 (edited) Nope, one coat did it for the hood, I had a bad scrape on the side and it did take 2 passes, I don't even notice it now. Hi. I ordered a kit for my Beamer in Apr. Tried it in a few spots on the hood with fairly good results. I haven't tried it on the scrape on the driver's side door yet... Did you use a t-shirt rag, cloth, or actually brush/dab it and wipe with your thumb and included glove? Edited May 8, 2009 by BlueSteel530i Quote Link to comment Share on other sites More sharing options...
0 ozzy Posted May 8, 2009 Share Posted May 8, 2009 brush/dab it and wipe with your thumb, this was the way I did most of it, seemed to work for me. Quote Link to comment Share on other sites More sharing options...
0 SpicyGTO Posted May 8, 2009 Share Posted May 8, 2009 Does anyone have before/after pics of chips using this product. I just finished fixing several chips with langka and I thought it worked pretty well, however for bigger chips wet sanding still yeilds better results. Quote Link to comment Share on other sites More sharing options...
0 JJ1o87 Posted May 11, 2009 Share Posted May 11, 2009 I'm completely fed up with this crap product. Dr. Color Chip DOES NOT WORK! I even clay barred and used rubbing alcohol on the chip before I applied the stuff this time and guess what - it still DOESN'T WORK! I'm going to send them a nasty email now. Quote Link to comment Share on other sites More sharing options...
Cyclone
22 answers to this question
