tigris1997 Posted July 15, 2009 Share Posted July 15, 2009 After I apply VRT to the back of my outside mirrors on my Chev. P/U the next day they are all streaks. I beleave it is the night dew doing it. Any sugestions how to elimate this problem? Link to comment Share on other sites More sharing options...
0 Team Adam's Posted July 15, 2009 Share Posted July 15, 2009 VRT is water based, so you are correct in assuming it is the dew. Next time you apply VRT try wiping the panel down with a blast of detail spray and a clean MF cloth afterwards. This will remove any excess product and hopefully leave less behind for the dew to impact. If you're still seeing the problem then you may need to build a garage Link to comment Share on other sites More sharing options...
0 11chevz71 Posted July 15, 2009 Share Posted July 15, 2009 VRT is water based, so you are correct in assuming it is the dew. Next time you apply VRT try wiping the panel down with a blast of detail spray and a clean MF cloth afterwards. This will remove any excess product and hopefully leave less behind for the dew to impact. If you're still seeing the problem then you may need to build a garage Link to comment Share on other sites More sharing options...
0 tigris1997 Posted July 15, 2009 Author Share Posted July 15, 2009 VRT is water based, so you are correct in assuming it is the dew. Next time you apply VRT try wiping the panel down with a blast of detail spray and a clean MF cloth afterwards. This will remove any excess product and hopefully leave less behind for the dew to impact. If you're still seeing the problem then you may need to build a garage I have a garage, that is reserved for the Vette! Link to comment Share on other sites More sharing options...
0 jjwvette Posted July 15, 2009 Share Posted July 15, 2009 You need some In and Out spray:) try asking around...some of the dealers might have some hidden..... Link to comment Share on other sites More sharing options...
0 GerryC Posted July 15, 2009 Share Posted July 15, 2009 Hard exterior plastics will not absorb VRT like softer materials such as tires and weatherstrip. If you are seeing streaks you probably applied too much, so just do what Dylan suggested and you should be fine. Link to comment Share on other sites More sharing options...
0 Chewy Posted July 15, 2009 Share Posted July 15, 2009 Had the same problem on our jet ski the other day. I just added more after the fun on the water... Chris Link to comment Share on other sites More sharing options...
0 Nickc0844 Posted July 24, 2009 Share Posted July 24, 2009 ...and it's certainly better than the alternative of using a heavily based petroleum product that would otherwise attract a ton of dust, bugs, etc...and eventually brown Link to comment Share on other sites More sharing options...
0 tigris1997 Posted July 24, 2009 Author Share Posted July 24, 2009 You need some In and Out spray:) try asking around...some of the dealers might have some hidden..... I have tried your sugestion and it works fine and no streaks. Link to comment Share on other sites More sharing options...
0 Adam Posted July 24, 2009 Share Posted July 24, 2009 I have tried your sugestion and it works fine and no streaks. Right on Paul!!! Thanks for your post of the results, and thank you for your business! -Adam:) Link to comment Share on other sites More sharing options...
tigris1997
9 answers to this question
