Shopkins Posted July 17, 2009 Share Posted July 17, 2009 Newbie here so please be easy! I have used the zaino product that removes the spots off the glass. Is there an Adam's product that does the same? Maybe one that you don't have to worry about getting it on the window trim. Thanks for any suggestions! Sean Link to comment Share on other sites More sharing options...
0 GerryC Posted July 17, 2009 Share Posted July 17, 2009 It depends on the severity of the spots, how long they've been there, etc. I would start with some Glass Cleaner and a microfiber towel. If they don't come off completely, others have had good results using a clay bar on the glass to remove spots, using Detail Spray (or All Purpose Cleaner if they are really stubborn) as a lubricant. If you can take a photo and post it for us we can better know how to treat your particular situation:thumbsup: Link to comment Share on other sites More sharing options...
0 Superdutytd Posted July 17, 2009 Share Posted July 17, 2009 If they are really bad you can polish them using SHR/FMP and an Orange/White pad. Link to comment Share on other sites More sharing options...
0 Rich Posted July 17, 2009 Share Posted July 17, 2009 (edited) I'd recommend using Adam's Glass Cleaner and the special Adam's glass cloths. They happen to be an advertised special right now too. Follow up with a treatment with the Brilliant Spray Glaze and you should be good to go. Edited July 18, 2009 by Rich Link to comment Share on other sites More sharing options...
0 11chevz71 Posted July 17, 2009 Share Posted July 17, 2009 Im with rich and gerry Link to comment Share on other sites More sharing options...
0 Superdutytd Posted July 18, 2009 Share Posted July 18, 2009 I don't know about you guys but even using the claybarring and glass cleaner I could never get any real major water spots to come off. Link to comment Share on other sites More sharing options...
0 GerryC Posted July 18, 2009 Share Posted July 18, 2009 If the spots aren't etched in then clay should be able to remove them,as technically the would be impurities on top of the glass. Polish would probably work too but he doesn't want to accidentally stain his trim. I stained some black trim on my Taurus with SHR and the only thing that was able to get it all out was GWC, a toothbrush, and lots of scrubbing Again it depends on how bad the spots are but any of the methods mentioned in this topic should help Link to comment Share on other sites More sharing options...
0 Shopkins Posted July 18, 2009 Author Share Posted July 18, 2009 I will try these ideas. I used the Zaino on the wife's Z28 and it took all the water spots off. Even took them of the T-tops. It's a liquid and as you rub it on it turns to a paste. Then just wipe it off. Took about a year before the spots started to come back. I have yet to do it to my truck. I will get some pictures. Thanks Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted July 18, 2009 Share Posted July 18, 2009 I'd just tape up the trim before polishing to be safe Link to comment Share on other sites More sharing options...
0 AZGTO Posted July 19, 2009 Share Posted July 19, 2009 The new adams glass cleaner works awesome...so awesome I bought a gallon of it..if that doesn't work then do what everyone else said use a claybar and try that Link to comment Share on other sites More sharing options...
0 jjwvette Posted July 19, 2009 Share Posted July 19, 2009 Do you remember what it was called? I used Zanio and never heard of a product they had for removing water spots:) You'll find Adams much easier to use:banana: Link to comment Share on other sites More sharing options...
Shopkins
Sean
10 answers to this question
