I washed, clayed, orange pad + SHR, then white pad + FMP.
Car was new in February and has never had any product on it before this. I only took it through touchless washes until I started the process.
Process using PC:
1. I worked the hood in 6 sections.
2. When I used orange pad I used 3 pea sized drops each section. Speed 3 ro spread product, worked with speed 5.
3. When I use I used FMP I started with 3 pea sized drops on first section, used a spritz of DS on the pad. Then I spread the product on speed 3. Then I did 2 passed on speed 6. Then I spritzed the pad again and worked the product on speed 5 until it looked like grease.
4. After the first section I used 2 pea sized drops and a spritz of spray, then repeated previous step.
5. I never had the PC in one spot more than 2 seconds tops (and I am sure that is way longer), but usuallt less than one as I moved it across the area.
It wasn't until I finished wiping the FMP off that I noticed these 2 spots in the paint. I tried to re-work the area again and it didn't help at all. The clear coat seems fine.
Questions:
1. Any chance I caused this with the PC?
2. How do I get it out?
Sorry for the crappy picture but I used my camera phone. I had both halogens on this area lighting it for the picture.
MitsukiGT
Process using PC:
Questions:
Edited by MitsukiGTLink to comment
12 answers to this question
