VertimgoC502 Posted January 5, 2010 Share Posted January 5, 2010 What should I use to clean a convertible top? Link to comment Share on other sites More sharing options...
NightMare Silverado Posted January 5, 2010 Share Posted January 5, 2010 we used waterless car wash on my brothers mustang top and then put VRT on it and it looked 100% better. Link to comment Share on other sites More sharing options...
VertimgoC502 Posted January 5, 2010 Author Share Posted January 5, 2010 I have a light color and need to "scrub" a few marks. Any idea of the type of brush? Link to comment Share on other sites More sharing options...
Chris@Adams Posted January 5, 2010 Share Posted January 5, 2010 I would use APC and a soft brush! Try diluted first! SKU:D015D025 Price: $8.95 <SCRIPT language=JavaScript type=text/javascript><!--var VariantMinimumQty_121_133 = 0;var SelectedVariantInventory_121_133 = 998789;function AddToCartForm_121_133_Validator(theForm) { submitonce(theForm); if ((theForm.Quantity.value*1) < 1) { alert("Please specify the quantity you want to add to your cart"); theForm.Quantity.focus(); submitenabled(theForm); return (false); } submitenabled(theForm); return (true); }//--></SCRIPT><FORM id=AddToCartForm_121_133 style="MARGIN-TOP: 0px; MARGIN-BOTTOM: 0px" name=AddToCartForm_121_133 onsubmit="return validateForm(this) && AddToCartForm_121_133_Validator(this)" action=addtocart.aspx?returnurl=showproduct.aspx%3fProductID%3d121%26SEName%3dadams-all-purpose-cleaner method=post><INPUT id=VariantStyle type=hidden value=0 name=VariantStyle><INPUT id=IsWishList type=hidden value=0 name=IsWishList><INPUT id=IsGiftRegistry type=hidden value=0 name=IsGiftRegistry><INPUT id=UpsellProducts type=hidden name=UpsellProducts> <INPUT id=CartRecID type=hidden value=0 name=CartRecID> <INPUT id=ProductID type=hidden value=121 name=ProductID> <INPUT id=VariantID type=hidden value=133 name=VariantID> <SMALL>Quantity:</SMALL> <INPUT id=Quantity onkeyup="if(typeof(getShipping) == 'function'){getShipping()}" maxLength=4 onchange="if(typeof(getShipping) == 'function'){getShipping()}" size=3 value=1 name=Quantity><INPUT type=hidden value="[req][integer][number][blankalert=Please enter a quantity][invalidalert=Please enter a number for the quantity]" name=Quantity_vldt> <INPUT class=AddToCartButton onclick="document.AddToCartForm_121_133.IsWishList.value='0';document.AddToCartForm_121_133.IsGiftRegistry.value='0';if(validateForm(document.AddToCartForm_121_133) && AddToCartForm_121_133_Validator(document.AddToCartForm_121_133)) {document.AddToCartForm_121_133.submit();}" type=button value="Add to Cart"></FORM> <SCRIPT type=text/javascript>var addthis_pub="scott111";</SCRIPT><SCRIPT src="http://s7.addthis.com/js/200/addthis_widget.js" type=text/javascript></SCRIPT> Adam's All-Purpose Cleaner Tough on dirt, but easy on your car! Adam's All-Purpose Cleaner replaces a whole shelf full of automotive cleaners for wheels, tires, engine, tar, insects and more! At Adam's Polishes, if a product isn't safe, easy and effective, we kick it to the curb. Our Adam's All-Purpose Cleaner isn't rocket science, but it effectively cleans the worst grime your car brings home without being harsh or harmful to any surface. On tires and wheels, Adam's All-Purpose Cleaner removes the worst caked on brake dust build-up you can imagine, without the acids and cheap butyls found in most wheel cleaners that cause wheel damage (etching) and pollute the earth. Adam's All-Purpose Cleaner deep cleans tires, removing browning and old tire dressing without leaching the tire's built-in wax protection. Use Adam's All-Purpose Cleaner under the hood to degrease your engine. Dirt, grime, grease and oil literally melt away when you apply Adam's All-Purpose Cleaner at full strength. For a lightly soiled engine, you can dilute Adam's All-Purpose Cleaner 5:1 with water. Use Adam's All-Purpose Cleaner on the worst grime your car has, including the undercarriage, road tar, sap, bugs, bird droppings, just about any soil you can imagine is easily and safely removed with the proper mixture of Adam's All-Purpose Cleaner! Link to comment Share on other sites More sharing options...
NightMare Silverado Posted January 5, 2010 Share Posted January 5, 2010 We used the red applicator pad for cleaning as well as applying the vrt. This mustang had never had a 'real" detail in 50,000 miles it was a grey top before I got to it. Link to comment Share on other sites More sharing options...
bigred vette Posted January 5, 2010 Share Posted January 5, 2010 Vrt or WW won't work on our cloth tops. Try the apc or carpet and upholstery cleaner with a soft bristled brush. Link to comment Share on other sites More sharing options...
VertimgoC502 Posted January 5, 2010 Author Share Posted January 5, 2010 Thanks for the input. I will begin building another order for Adam's! Link to comment Share on other sites More sharing options...
Bill-V8V Posted January 5, 2010 Share Posted January 5, 2010 Vrt or WW won't work on our cloth tops. Try the apc or carpet and upholstery cleaner with a soft bristled brush. I agree but cut the APC at least 50/50 for starters Link to comment Share on other sites More sharing options...
b_pappy Posted January 5, 2010 Share Posted January 5, 2010 Good advice on using APC and a upholstery brush, start at 50%, diluted with distilled water. If that isn't getting it out bump up the strength to 100% strength APC. You can also use the Carpet & Upholstery Cleaner. I've got an oak colored top on my Corvette also, never got all the spots out, but much better. My top was really neglected when I got it though. Concentrate on the spots, but do the entire top. You will also want to go back and wax the body afterwards. Bruce Link to comment Share on other sites More sharing options...
VertimgoC502
8 answers to this question
