SPP R/T Posted June 22, 2010 Share Posted June 22, 2010 My daughter has a Ford Escape with those lower plastic body panels,got tar on them (tried search) any good ways of removing this. THANKS IN ADVANCE , Wolffy:burnout: Link to comment Share on other sites More sharing options...
Huckleberry Posted June 22, 2010 Share Posted June 22, 2010 Have you been down to the gulf coast or something? Link to comment Share on other sites More sharing options...
IowaEmt1991 Posted June 22, 2010 Share Posted June 22, 2010 WD-40 seems to work pretty good..Just make sure you clean the area VERY good after you do it..and follow up with your normal detailing process Link to comment Share on other sites More sharing options...
Chris@Adams Posted June 22, 2010 Share Posted June 22, 2010 If its not too thick clay bar will work, but you will have to toss the clay when done! Link to comment Share on other sites More sharing options...
Kingsford Posted June 22, 2010 Share Posted June 22, 2010 Good ol' Clay Bar and Detail Spray always work for me to get tar off! Link to comment Share on other sites More sharing options...
Superdutytd Posted June 22, 2010 Share Posted June 22, 2010 Let some APC or GWC soak on it for a while should usually work too. Link to comment Share on other sites More sharing options...
Chewy Posted June 22, 2010 Share Posted June 22, 2010 My daughter has a Ford Escape with those lower plastic body panels,got tar on them (tried search) any good ways of removing this. THANKS IN ADVANCE , Wolffy:burnout: I had a 2002 Escape with the plastic lowers and I would NEVER say use clay on them. It just won't work IMO. I'd use WD-40 or IMO better yet Kerosene on a rag and wipe. I use 3M adhesive remover which is made for car finishes and it works great. Always try on an inconspicuous area of course. Coat with some Super VRT and you'll be golden! Chris Link to comment Share on other sites More sharing options...
Kingsford Posted June 22, 2010 Share Posted June 22, 2010 I use 3M adhesive remover which is made for car finishes and it works great. Always try on an inconspicuous area of course. Coat with some Super VRT and you'll be golden! Chris Maybe try some Goo Gone and give it a good bath afterwards. Link to comment Share on other sites More sharing options...
mikeg6045 Posted June 22, 2010 Share Posted June 22, 2010 I had a 2002 Escape with the plastic lowers and I would NEVER say use clay on them. It just won't work IMO. I'd use WD-40 or IMO better yet Kerosene on a rag and wipe. I use 3M adhesive remover which is made for car finishes and it works great. Always try on an inconspicuous area of course. Coat with some Super VRT and you'll be golden! Chris yup, 3m adhesive remover will take it right off. just follow the instructions and dont let it dry on its own. I use that stuff on everything including the vinyl house siding. Link to comment Share on other sites More sharing options...
Chewy Posted June 22, 2010 Share Posted June 22, 2010 yup, 3m adhesive remover will take it right off. just follow the instructions and dont let it dry on its own. I use that stuff on everything including the vinyl house siding. Yep! Goo-Gone has nothing on this stuff... I bought a can of it 2 years ago and I've used probably 4 tablespoons from it! lol Chris Link to comment Share on other sites More sharing options...
SPP R/T Posted June 24, 2010 Author Share Posted June 24, 2010 I bought some 3M remover, I'll try it this weekend and let you all know how it turns out. Thanks for the ideas. Wolffy:rockon::rockon: Link to comment Share on other sites More sharing options...
mikeg6045 Posted June 29, 2010 Share Posted June 29, 2010 I bought some 3M remover, I'll try it this weekend and let you all know how it turns out. Thanks for the ideas. Wolffy:rockon::rockon: even though i have used it safely many times, I advise you always try a small test spot, and after you have removed it, wait for the spot to air out completely to test for colorfastness. remember to never let the product dry on its own. i'm not sure if it says that on the bottle, but i would have to imagine its the safer route. It works so well, that a couple seconds and then a swipe with a towel will show its full potential anyway. I just want to make sure you use it safely, as it has worked very well for me in the past, but always remember that most all 3M products are made for the professional market (which is why there always in a different section from the regular car care isle in stores). Link to comment Share on other sites More sharing options...
SPP R/T
11 answers to this question
