Alex Ross Posted November 22, 2008 Share Posted November 22, 2008 Hi, I am designing a catalog however the photos have a background, for example the pictures are of shoes but i can see the table the shoe is sitting on and the background behind the shoe, is there a way to cut the shoes out in Photoshop so the background is removed? Thanks Link to comment Share on other sites More sharing options...
Marylander Posted November 22, 2008 Share Posted November 22, 2008 As you know, photoshop is an amazingly complex and powerful tool, and as such there are several ways to select just part of an image (the shoe) and remove the unwanted areas (the background). I would suspect that for an object with relatively clean edges (like a shoe) your best bet would be to create a path around the shoe, turn that into a selection, selecting inverse, and then deleting the background. That's the 10 second answer. If you do a google search on the topic you'll find lots of photoshop "how-to" type sites. Photoshop is one of those amazing tools that no matter how much you use it you're always finding new tricks and powers... My advice is just to play around and practice, and soon enough you'll be getting better and better results. Have fun! Rich Link to comment Share on other sites More sharing options...
3gInOc Posted November 25, 2008 Share Posted November 25, 2008 the above is correct to an extent. i do agree there are 100 different ways to do things in photoshop. the problem your going to run into with just making a selection and deleting the background is going to be at the RIP stage. If this is for a catalog then you will have to save this file out as psd and place into a layout program. then you have to hope that it is on a plain white background. otherwise you will end up with white bounding box. a clipping path is the only true way to do this. using the method above will work, but it is the quick fix. do some research on how to create a clipping path. once you get the hang of it, you will see its very easy. Link to comment Share on other sites More sharing options...
Cyclone Posted November 27, 2008 Share Posted November 27, 2008 If its not clean lines around it, I have found the eraser to work wonders to trim a piece out... Then you can simply cut it out Link to comment Share on other sites More sharing options...
