Ok so I am putting this out here in the hopes that the Adam's crew will see it and make them a reality.
The two brushes offered for the wheels and the tires are "ok" but I think there is a LOT of room for improvement for both of these items.
The tire brush could stand to be slightly stiffer, slightly curved inward in the center, rectangle in shape and have an oval shaped or bent J style handle to allow for a better scrubbing with more control of the bristle path to keep off of the wheel itself.
The wheel brush should either be offered double ended or more of a rounded end with cleaning bristles slightly shorter while being soft and non scratching. The exposed solid edges of the brush should have a non marring rubber type edge covering to aid in preventing dinging of the wheel or finish when cleaning. Also, too often when using the wheel brush with the wheel cleaner I have to use my finger tips to agitate the cleaner to loosen the dirt and grime from my wheels or will be faced with many areas that will have to be re cleaned as the car is being dried. Even after using G&G on the wheels etc this still is an issue.
Cleaning brushes are a pivotal part of any cleaning arsenal, the wheel woolie and the fast stick are awesome products....how about refining the brushes some and don't let the local auto parts box store and Walmart brushes out do ya.
dskinsler83
I say all this with love though! :->
Edited by dskinsler83Link to comment
19 answers to this question
