I was using FMP on my wife's Trailblazer last week and it seemed to be drying too fast and had next to no working time. You could actually see lines in the paint where the polish seemed to completely dry out. Temperature was about 75 degrees and slightly humid out, not bad for polishing. Vehicle was in the garage so sun wasn't an issue.
The problem occurred with both the Flex and PC and Adam's pads. I tried speeds between 3 and 5 and differing amounts of detail spray but it was next to impossible to get out the marring from SHR. Ended up putting a CCS pad on the flex and use Menz polish to fix the bit I started. I used the X for the polish amount on the Flex and a single shot of DS, 3 pea size drops on the PC and another shot of DS. I had under 1 minute of working time. I would almost continually have to keep spraying the pad with DS to work the polish in. SSR & SHR were fine under the same conditions.
Heineken
Anyone else have this issue?
15 answers to this question
