bonedr Posted August 3, 2011 Share Posted August 3, 2011 just wondering does detail spray have any carnuba in it?? Link to comment Share on other sites More sharing options...
Chewy Posted August 3, 2011 Share Posted August 3, 2011 NONE! It's got some oils in it to make the paint POP. It's also silicon free! Chris Link to comment Share on other sites More sharing options...
J Tegeler Posted August 3, 2011 Share Posted August 3, 2011 psh, well foam tek waterless wash has ionized carnuba! Link to comment Share on other sites More sharing options...
obssest Posted August 4, 2011 Share Posted August 4, 2011 Does Detail Spray repel water in any way? I generally use the DS as a drying aide. A couple days later, if I dust and wipe down with the Waterless Wash, is the WCW going to remove the DS to such an extent that I should DS again after the WCW? Link to comment Share on other sites More sharing options...
musclejunkie Posted August 4, 2011 Share Posted August 4, 2011 The only thing Detail Spray contains is MAGIC Link to comment Share on other sites More sharing options...
Chewy Posted August 4, 2011 Share Posted August 4, 2011 Does Detail Spray repel water in any way? I generally use the DS as a drying aide. A couple days later, if I dust and wipe down with the Waterless Wash, is the WCW going to remove the DS to such an extent that I should DS again after the WCW? Yes, but only for a short time. The oils in the DS will make water bead up pretty well. WCW WILL remove DS. Most will wash with WCW and then shine it up with DS. DS isn't designed to last any length of time. It's more for when you get to the car show, to add that last POP to the paint and remove light dust along the way. Chris Link to comment Share on other sites More sharing options...
J Tegeler Posted August 4, 2011 Share Posted August 4, 2011 I agree, It always adds that little extra pop to the paint when drying the car, follow that up with a coat of buttery or americana to really add a wow factor and to bead the water Link to comment Share on other sites More sharing options...
Chris@Adams Posted August 4, 2011 Share Posted August 4, 2011 The only thing Detail Spray contains is MAGIC Link to comment Share on other sites More sharing options...
Dv3andrs Posted August 8, 2011 Share Posted August 8, 2011 I finally used the detail spray trick while drying the other day and couldn't believe the bling! My wife came home and thought I had taken the time to wax the truck. I need to find a really nice shady spot to work on this thing though, I had to rewet the panels because of the crazy hot sun, still awesome though!! Link to comment Share on other sites More sharing options...
J Tegeler Posted August 8, 2011 Share Posted August 8, 2011 I always use the DS while drying and love the results. sometiems i even go over the car with a WW towel and DS after drying the car to Link to comment Share on other sites More sharing options...
bonedr
9 answers to this question
