I just ordered the quick disconnect kit, along with the daily special and shut-off valve. I plan to use the quick disconnect to go from a fire hose head and a pressure washer.
Though, I may of over thought the quick disconnect. I added an additional female coupler with plans to use on the outside faucet head to quickly remove the hose for safe storage. Essentially, I'd be using two quick disconnects on a single hose, to connect it to the water source and to the tools.
The question: Will that restrict the water too much, using two?
Also, while I'm here, might as well ask: Are there any good hoses I should get at OSH, Home Depot or Lowes?
Brian123
5 answers to this question
