Lyn gave me a car cover for Christmas. It is designed for indoor protection which is what I will use it for ( use to use sheets to defend against dust in garage to reduce amount of washes needed on Black Vette). Noticed instructions state do not cover a wet vehicle. Here is the situation.......
Wahed Vette starting around 2 pm. After washed decided to put on Brilliant Glaze followed by wax. Put on Brilliant Glaze but felt not enough time left to wax ( it is dark around 5 p m). Put Vette in garage and placed new cover thereon (first time used). Instructions state cover is designed to avoid moisture damage to vehicle.....beathable to allow escape of evaporating moisture and heat. But then says to not cover a wet vehicle. I do not consider vehicle to be wet, however, there is no doubt there is some residual moisture from the wash. Will this plus the application of Brilliant Glaze immediately prior to placing the cover be likely to cause a problem??
Its terrible to be OCD about this....afterall it is just a car !!??
edit...The temperature at washing and glazing was around 48 degrees.
Vette is in garage. Tonight temp will drop to 40 degrees. Tomorrow will be 55 degrees.
xlr8rvette
Edited by xlr8rvetteLink to comment
4 answers to this question
