Dura13 11 Posted March 31, 2013 Share Posted March 31, 2013 Anyone else have a newer diesel and have deisel exhaust fluid (DEF) "markings" in the engine bay? What are you using to keep it clean? Thanks! Quote Link to post Share on other sites
0 carlrx7 33 Posted March 31, 2013 Share Posted March 31, 2013 I'll take a look, but don't think i have any of those markings in my 13' VW Passat TDI Quote Link to post Share on other sites
0 LFairbanks 1,020 Posted March 31, 2013 Share Posted March 31, 2013 Anyone else have a newer diesel and have deisel exhaust fluid (DEF) "markings" in the engine bay? What are you using to keep it clean? Thanks! I do. But Iam not sure what it is that your asking. Quote Link to post Share on other sites
0 paoutdoorsman 44 Posted March 31, 2013 Share Posted March 31, 2013 (edited) Anyone else have a newer diesel and have deisel exhaust fluid (DEF) "markings" in the engine bay? What are you using to keep it clean? Thanks! Yeah, you do not want to spill DEF on anything - especially bare metals. If you do, you'll want to wash away with water before being allowed to dry. DEF is basically urea, and is corrosive for many metals including carbon steel, copper, aluminum, and zinc. Edited March 31, 2013 by paoutdoorsman Quote Link to post Share on other sites
0 Dura13 11 Posted March 31, 2013 Author Share Posted March 31, 2013 I haven't added any, yet. So, I'm not sure where it is coming from... Does it leave stains, and do the Adams cleaners do a good job of cleaning it up? Thanks! Quote Link to post Share on other sites
0 LFairbanks 1,020 Posted March 31, 2013 Share Posted March 31, 2013 I have never spilt any. I have a funnel that I use that is dedicated to DEF. If it dries it because like a white crusty material. Like was mentioned earlier rinse it off immediately if you do spill it. And be careful of where you put that rinse water. Not sure what vehicle you have, but I have a 2011 Duramax and there is a small hole right next to the fill tube that is kind of like an overflow that flows back in the DEF tank that is just open. Probably not a good idea to get water in there. Quote Link to post Share on other sites
0 Dura13 11 Posted April 1, 2013 Author Share Posted April 1, 2013 It's a 2013 Silverado with the Duramax. I've never had to deal with the DEF before, so looking for learn from others experiences. I had not noticed the 'air' hole, so may need to find a way to 'manage' that, as I have the 'white crusties' all over the passenger side of the engine bay... Quote Link to post Share on other sites
0 Marylander 518 Posted April 1, 2013 Share Posted April 1, 2013 Just curious... My 2010 vw diesel doesn't require that stuff (happily), but I'm curious as to what it costs to refill these systems, and how often you have to do it? This diesel being my first, I REALLY like diesel vehicles now. They'll be high on my list for any future motor, when available. Quote Link to post Share on other sites
0 LFairbanks 1,020 Posted April 1, 2013 Share Posted April 1, 2013 Just curious... My 2010 vw diesel doesn't require that stuff (happily), but I'm curious as to what it costs to refill these systems, and how often you have to do it? This diesel being my first, I REALLY like diesel vehicles now. They'll be high on my list for any future motor, when available. Rich it really isn't bad at all. It is amazing how much cleaner it is. The exhaust tip isn't all black and sooty. You can pick up the stuff at any auto parts store and I have found it to be around 10-13 bucks for 2.5 gallons. But it can be bought for 3 bucks a gallon from what I have heard at places. Never have seen that first hand however. I have never run out and I have a 5 gallon tank on mine. They say it should be topped off at every oil change. I usually just keep it full. And pick up a jug here and there. It will give you warnings as it gets low and I have never seen that. FAQ - discover Diesel Exhaust Fluid (DEF) Quote Link to post Share on other sites
0 Marylander 518 Posted April 1, 2013 Share Posted April 1, 2013 (edited) Rich it really isn't bad at all. It is amazing how much cleaner it is. The exhaust tip isn't all black and sooty. You can pick up the stuff at any auto parts store and I have found it to be around 10-13 bucks for 2.5 gallons. But it can be bought for 3 bucks a gallon from what I have heard at places. Never have seen that first hand however. I have never run out and I have a 5 gallon tank on mine. They say it should be topped off at every oil change. I usually just keep it full. And pick up a jug here and there. It will give you warnings as it gets low and I have never seen that. FAQ - discover Diesel Exhaust Fluid (DEF) Interesting. My "clean diesel" vw has what they call a diesel particular filter that collects the higher soot generated at startup and then every few hundred miles or so heats up the collector and burns it off. Most of the time you're never even aware of it happening. The tailpipe of the car never gets dirty all. In fact, I've seen vw videos of guys covering the pipe with a coffee filter, running the car for a while, and then using the filter to make coffee (and drinking it!). I wonder which approach is simpler and more reliable? Edited April 1, 2013 by MarylandTDI Quote Link to post Share on other sites
0 LFairbanks 1,020 Posted April 1, 2013 Share Posted April 1, 2013 (edited) I know the Duramax has that filter in conjunction with the DEF. http://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals%20and%20Videos/02_pdf/SilveradoHD_DEF.pdf You can see in my below picture how clean the exhaust tip is. Notice the inside of the pipe isn't all black. You can literally walk up to it while idling and there is almost no smell at all. And definitely not that usual diesel smell. Edited April 1, 2013 by LFairbanks Quote Link to post Share on other sites
0 paoutdoorsman 44 Posted April 1, 2013 Share Posted April 1, 2013 In the newer systems with DEF, the DEF is used to generate the high heat necessary to burn out the particulate filter. In the earlier particulate filter systems, at least with the GM's, diesel was injected and burnt in the exhaust post turbo to generate the the heat needed to burn out the filter. The urea is just supposed to be an improvement over that original design. Quote Link to post Share on other sites
0 RAT 11 Posted April 1, 2013 Share Posted April 1, 2013 I have burned over 70 gallons in my 2011 Duramax. Nothing cleans it up if it dries. APC is your best bet if you can catch it right away. Quote Link to post Share on other sites
0 LFairbanks 1,020 Posted April 1, 2013 Share Posted April 1, 2013 In the newer systems with DEF, the DEF is used to generate the high heat necessary to burn out the particulate filter. In the earlier particulate filter systems, at least with the GM's, diesel was injected and burnt in the exhaust post turbo to generate the the heat needed to burn out the filter. The urea is just supposed to be an improvement over that original design. 2 Comments robert beasley | February 14, 2012 3:40 PM | Reply Does the Diesel Exhaust Fluid get injected into the exhaust during system regeneration? Editor replied to comment from robert beasley | February 14, 2012 6:44 PM | Reply For Diesel Particulate Filter regeneration, diesel fuel is injected into the exhaust system ahead of the Diesel Oxidation Catalyst to raise the temperature of the exhaust needed for regeneration. The aftertreatment system, which reduces emissions, uses Diesel Exhaust Fluid (DEF) to react with NOx to convert exhaust pollutants into nitrogen, water and trace amounts of CO2. Duramax Diesel Exhaust System Fluid Injectors - GM Techlink Quote Link to post Share on other sites
0 carlrx7 33 Posted April 1, 2013 Share Posted April 1, 2013 oh,,, ok, vw calls it Adblue, my tank is in the trunk, heard it makes white crystals if spilt and hard to clean up, mostly stains the carpet. Quote Link to post Share on other sites
0 KKJ 16 Posted April 2, 2013 Share Posted April 2, 2013 I know the Duramax has that filter in conjunction with the DEF. http://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals%20and%20Videos/02_pdf/SilveradoHD_DEF.pdf You can see in my below picture how clean the exhaust tip is. Notice the inside of the pipe isn't all black. You can literally walk up to it while idling and there is almost no smell at all. And definitely not that usual diesel smell. Is that a picture of your pickup's tailpipe? If you polished it, how did you do it? It looks amazing compared to mine! I was thinking about painting mine black, but I really like the way this looks. Maybe I should just do the DPF delete and make it naturally black. Quote Link to post Share on other sites
0 Chuckkilo3 19 Posted April 2, 2013 Share Posted April 2, 2013 Is that a picture of your pickup's tailpipe? If you polished it, how did you do it? It looks amazing compared to mine! I was thinking about painting mine black, but I really like the way this looks. Maybe I should just do the DPF delete and make it naturally black. You don't want to mess around with emissions stuff. Quote Link to post Share on other sites
0 blcksilv08 420 Posted April 2, 2013 Share Posted April 2, 2013 Warm water cleans it off fairly well with apc mixed after it has dried, have to clean it off Mercedes Sprinter vans plastic grills and Freightliner medium and heavy trucks all the time at work, some people just cant pour a liquid without a mess. Quote Link to post Share on other sites
0 LFairbanks 1,020 Posted April 2, 2013 Share Posted April 2, 2013 Is that a picture of your pickup's tailpipe? If you polished it, how did you do it? It looks amazing compared to mine! I was thinking about painting mine black, but I really like the way this looks. Maybe I should just do the DPF delete and make it naturally black. Metal Polish 1 and 2. And that was it. Made sure it was clean of course before starting. Quote Link to post Share on other sites
0 eric@thompsonracing.us 164 Posted April 2, 2013 Share Posted April 2, 2013 My brother ripped all the urea and DPF crap off his '12 Dmax. Runs much better and cheaper. I had an '06 LBZ without all the DPF junk and got much better mileage than his '12. You can thank our corrupt liberal government for the progression of ignorance toward diesel technology. Emmissions on a diesel and diesel fuel prices is a crime. If you want to prevent urea spots in your engine bay, rip out all the DPF junk and make it run like a real diesel. Quote Link to post Share on other sites
0 RAT 11 Posted April 2, 2013 Share Posted April 2, 2013 My brother ripped all the urea and DPF crap off his '12 Dmax. Runs much better and cheaper. I had an '06 LBZ without all the DPF junk and got much better mileage than his '12. You can thank our corrupt liberal government for the progression of ignorance toward diesel technology. Emmissions on a diesel and diesel fuel prices is a crime. If you want to prevent urea spots in your engine bay, rip out all the DPF junk and make it run like a real diesel. Thats fine as long as that emission police dont get you! Big NO,NO in Colorado! Quote Link to post Share on other sites
0 BrianT 579 Posted April 3, 2013 Share Posted April 3, 2013 Thats fine as long as that emission police dont get you! Big NO,NO in Colorado! EPA is fining H&S Performance and Edghe to name a few for selling delete systems! Not good!! Quote Link to post Share on other sites
0 Dura13 11 Posted April 3, 2013 Author Share Posted April 3, 2013 If you want to prevent urea spots in your engine bay, rip out all the DPF junk and make it run like a real diesel. I'm more interested in maintaining my 100,000 mile warranty, as we use the truck to tow. Not to mention the hassle of having to re-install it to get a emissions sticker... Quote Link to post Share on other sites
0 jordan572 27 Posted April 3, 2013 Share Posted April 3, 2013 My brother ripped all the urea and DPF crap off his '12 Dmax. Runs much better and cheaper. I had an '06 LBZ without all the DPF junk and got much better mileage than his '12. You can thank our corrupt liberal government for the progression of ignorance toward diesel technology. Emmissions on a diesel and diesel fuel prices is a crime. If you want to prevent urea spots in your engine bay, rip out all the DPF junk and make it run like a real diesel. Straight 5'' only, you haven't heard a truck until you here a duramax with 5''. The EPA has way to much power. Quote Link to post Share on other sites
0 jordan572 27 Posted April 3, 2013 Share Posted April 3, 2013 EPA is fining H&S Performance and Edghe to name a few for selling delete systems! Not good!! Yea that really pisses me off, lucky my brother got the hs setup before they went to the garbage street tuners. Quote Link to post Share on other sites
0 LDM 193 Posted April 4, 2013 Share Posted April 4, 2013 Straight 5'' only, you haven't heard a truck until you here a duramax with 5''. The EPA has way to much power. My brother has an '01 with a straight 5" Quote Link to post Share on other sites
Dura13 11
Thanks!
Link to post
25 answers to this question
