Capehorn3 Posted July 19, 2013 Share Posted July 19, 2013 Got some wax, Americana, on the rubber around rear glass and on the plastic cowl in front of windsheild. What are my options to remove? Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted July 19, 2013 Share Posted July 19, 2013 APC and a utility towel will do the trick! THE Mook 1 Link to comment Share on other sites More sharing options...
0 THE Mook Posted July 19, 2013 Share Posted July 19, 2013 What Chris says. Both of us. Chris@Adams 1 Link to comment Share on other sites More sharing options...
0 GerryC Posted July 19, 2013 Share Posted July 19, 2013 What Chris says. Both of us. I agree. Also listen to what Gerry said. Next time dress your rubber and plastic with SVRT before waxing, so if you do get some wax on a piece of trim, it will be easier to remove THE Mook, Norton and PacificNWBuckeye 3 Link to comment Share on other sites More sharing options...
0 Capehorn3 Posted July 19, 2013 Author Share Posted July 19, 2013 Thanks Guy's, will do this weekend. Link to comment Share on other sites More sharing options...
0 EPHIOS Posted July 19, 2013 Share Posted July 19, 2013 Super VRT before waxing works! Try it! Link to comment Share on other sites More sharing options...
0 Capehorn3 Posted July 19, 2013 Author Share Posted July 19, 2013 I did use VRT and blue tape before waxing and couldn't understand the white showing up around 10 days after waxing. At first I thought maybe it was a reaction between the VRT a freind gave me and the 303 Aerospace Protectant I had been using for years. But now I see the white residue is only in spots and a reaction would have been all over. I did get some tape release from the VRT and this is probably where some wax got through. EPHIOS 1 Link to comment Share on other sites More sharing options...
0 EPHIOS Posted July 19, 2013 Share Posted July 19, 2013 I did use VRT and blue tape before waxing and couldn't understand the white showing up around 10 days after waxing. At first I thought maybe it was a reaction between the VRT a freind gave me and the 303 Aerospace Protectant I had been using for years. But now I see the white residue is only in spots and a reaction would have been all over. I did get some tape release from the VRT and this is probably where some wax got through. Maybe that's part of your problem. Did you try to use AP cleaner to remove 303, before applying SVRT? In the past, I had the same problem on trims, when I switched from one product to he other, without stripping out the prior product. Link to comment Share on other sites More sharing options...
0 Capehorn3 Posted August 4, 2013 Author Share Posted August 4, 2013 As a follow up I used APC on trim and it removed all wax marks. Reapplied VRT and did a Brilliant Glaze layer on paint, looks so good! Thanks for the advice. Link to comment Share on other sites More sharing options...
0 KKJ Posted August 7, 2013 Share Posted August 7, 2013 I vote all purpose cleaner too, but I have also used WD-40 before I started using Adams products. Link to comment Share on other sites More sharing options...
Capehorn3
9 answers to this question
