EPHIOS Posted August 9, 2013 Share Posted August 9, 2013 Is the Grit Guard supposed to be moving, while you rub your pad or mitt on it? This is, of course, with water. Link to comment Share on other sites More sharing options...
0 goheels Posted August 9, 2013 Share Posted August 9, 2013 Nope. A spinning grit guard won't do a great job keeping the dirt trapped on the bottom. The "fins" of the guard should be flush on the bottom of the bucket, and it shouldn't move when you rub a pad/mitt on it. There are a couple of tricks that could help with a guard that is loose. One of these is to use zip ties on the outer edge to eliminate space between the guard and inner wall of the bucket. Link to comment Share on other sites More sharing options...
0 Chewy Posted August 9, 2013 Share Posted August 9, 2013 For some reason some people have issues with this. I too had this issue. I took cable ties (plastic ones) and wrapped them around the outer part of the GG and it seemed to keep it from moving. Link to comment Share on other sites More sharing options...
0 WildBillsBlueC6 Posted August 9, 2013 Share Posted August 9, 2013 I put a small sponge on the side when I press the grit guard into my bucket and that is enough to keep it from spinning. Link to comment Share on other sites More sharing options...
0 DirtyBlackHoe Posted August 9, 2013 Share Posted August 9, 2013 I have the same problem with mine...I shall try these techniques Link to comment Share on other sites More sharing options...
0 Feets31 Posted August 10, 2013 Share Posted August 10, 2013 I prop mine up on the side of the bucket so i can grab the guard and rub the pad against it with a little more force. Link to comment Share on other sites More sharing options...
0 scociny Posted August 10, 2013 Share Posted August 10, 2013 I use a 5 gal bucket from a home improvement store. The grit guard is too big for it, but it slides down to almost the bottom. If you push it down snug...it won't move and is still easy to get out. EPHIOS 1 Link to comment Share on other sites More sharing options...
0 EPHIOS Posted August 10, 2013 Author Share Posted August 10, 2013 I tried the zip ties. It works great! Link to comment Share on other sites More sharing options...
0 EPHIOS Posted August 10, 2013 Author Share Posted August 10, 2013 I use a 5 gal bucket from a home improvement store. The grit guard is too big for it, but it slides down to almost the bottom. If you push it down snug...it won't move and is still easy to get out. I just bought a bucket from Lowes and I cannot get the Grit Guard all the way down. I will be returning the bucket. Link to comment Share on other sites More sharing options...
0 goheels Posted August 10, 2013 Share Posted August 10, 2013 Bring your grit guard to lowes and test all their buckets. It was a little embarrassing but I got exactly what I needed without making several trips! Link to comment Share on other sites More sharing options...
0 scociny Posted August 11, 2013 Share Posted August 11, 2013 I just bought a bucket from Lowes and I cannot get the Grit Guard all the way down. I will be returning the bucket. Correct, it doesn't go all the way down and that is why I like it. I can wedge it down so it doesn't spin. To me, the grit guard is much more effective when it doesn't spin. Link to comment Share on other sites More sharing options...
0 CMDChase Posted August 11, 2013 Share Posted August 11, 2013 I tried the 5 gallon bucket too. Because it doesn't fit right, the grit guard eventually cracked the bucket. Link to comment Share on other sites More sharing options...
0 EPHIOS Posted August 11, 2013 Author Share Posted August 11, 2013 Anybody know where to buy 5 gallon buckets, other than from Adams, that are semi-transparent? Link to comment Share on other sites More sharing options...
0 EMMJAY Posted August 11, 2013 Share Posted August 11, 2013 I was under the impression that the grit guards lock in the adams buckets?...is this true?? Link to comment Share on other sites More sharing options...
0 mc2hill Posted August 11, 2013 Share Posted August 11, 2013 Anybody know where to buy 5 gallon buckets, other than from Adams, that are semi-transparent? I found one at Lowes that had graduated markings on it. It came from the paint section. The only problem was it became brittle after spending several summers in the garage. The Adam's bucket lives there too, but no issues with it. Link to comment Share on other sites More sharing options...
0 scociny Posted August 11, 2013 Share Posted August 11, 2013 I was under the impression that the grit guards lock in the adams buckets?...is this true?? That would be pretty cool...but they don't lock. They just sit freely in the bottom (I have the older small sized bucket). Link to comment Share on other sites More sharing options...
0 Mongosg8 Posted August 12, 2013 Share Posted August 12, 2013 My grit guards do not even hit the bottom of my two Adams 5 gal buckets. it doesn't spin but again they do not sit flush with the bottom of them. It was no issue with the old 4 gal bucket. Link to comment Share on other sites More sharing options...
0 EPHIOS Posted August 12, 2013 Author Share Posted August 12, 2013 Who made the buckets by Adams? Encore plastics? United plastics? Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted August 12, 2013 Share Posted August 12, 2013 http://www.adamsforums.com/topic/18871-tips-for-keeping-the-grit-guard-in-place/?hl=%2Bgrit+%2Bguard There's a couple more threads on the subject in here somewhere. Link to comment Share on other sites More sharing options...
EPHIOS
18 answers to this question
