Fit08 Posted April 27, 2014 Share Posted April 27, 2014 Anyone using the flex dual action with 4" pads? Link to comment Share on other sites More sharing options...
0 Fphillips Posted April 28, 2014 Share Posted April 28, 2014 Anyone using the flex dual action with 4" pads? You can't Link to comment Share on other sites More sharing options...
0 mtnbiker326 Posted April 28, 2014 Share Posted April 28, 2014 You can't use Adam's 4" pads. I have the 4" backing plate for my flex. But it only accepts 4" pads that are 4" minimum on the backing portion. Adam's pads are around 3.75" and thus won't fit. (they have the plastic ring around it so you can't get a secure bonding for the hook and loop backing to the plate) Link to comment Share on other sites More sharing options...
0 Fit08 Posted April 29, 2014 Author Share Posted April 29, 2014 You can't use Adam's 4" pads. I have the 4" backing plate for my flex. But it only accepts 4" pads that are 4" minimum on the backing portion. Adam's pads are around 3.75" and thus won't fit. (they have the plastic ring around it so you can't get a secure bonding for the hook and loop backing to the plate) Ok this is more the question I was wanting to ask from above quote. Can you use the flex dual action with smaller backing plates such as a 3.75 and who evers pads fit OR should this size only be used on a Porter cable OR flex rotoary?? Link to comment Share on other sites More sharing options...
0 Fphillips Posted April 29, 2014 Share Posted April 29, 2014 (edited) There only 2 backplates for the flex 3401. 5.5 inch and 4 3/8 inch. So the smallest pad u can use is 5.5 inch pad. I use 4inch pad on a PC. Edited April 29, 2014 by Fphillips Link to comment Share on other sites More sharing options...
0 mtnbiker326 Posted April 29, 2014 Share Posted April 29, 2014 There only 2 backplates for the flex 3401. 5.5 inch and 4 3/8 inch. So the smallest pad u can use is 5.5 inch pad. I use 4inch pad on a PC. Just to clarify, you are stating that there are 2 backing plates in addition to the standard plate that comes with all flexes as the 6.5"... correct? Link to comment Share on other sites More sharing options...
0 Fphillips Posted April 29, 2014 Share Posted April 29, 2014 Yes 2 backplates. 1 that's comes stock and the 4 3/8 inch BP. Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted April 30, 2014 Share Posted April 30, 2014 Captain Phillips is right. 4 3/8 bp on flex is meant for use with 5.5" pads. Stock plate on flex for 6.5" pads. My PC 7424 with 3" backing plate is relegated to 4" pad duty only nowadays since my FIL has a GG6 3rd gen. Still thinking about getting a Flex for myself but dropping the 250 or more on a used Flex is stretching the budget, whereas I could have my own GG6 with lifetime replacement for $130... Link to comment Share on other sites More sharing options...
0 mtnbiker326 Posted April 30, 2014 Share Posted April 30, 2014 (edited) I hate to disagree, but I have 3 backing plates. They are all different sizes. What I will agree with, is that yes the 4 3/8" bp (which is actually 3.75" actually pad space) is for the smaller normal 5.5" pads (not sold by Adam's) and the 4" focus pads will not fit. The stock bp is 5.5" for Adam's normal larger pads. The third bp is 6.5" which also works with Adam's pads (but is literally on the edge of the hook and loop) and any larger 7-8" pads. Edited April 30, 2014 by mtnbiker326 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted April 30, 2014 Share Posted April 30, 2014 I think the third BP is a sanding BP but don't quote me on it. The 2nd BP (5.75") is the one that comes with the 3401 as it will work with the 6.5" other brands (Adam's 7" comparable) pads Link to comment Share on other sites More sharing options...
0 mtnbiker326 Posted April 30, 2014 Share Posted April 30, 2014 True... But it is still sold as a set. I would agree that the larger one is for a buffer/sander application. http://www.autogeek.net/flex-hd-polisher-backing-plate.html (just for reference) The FLEX XC3401 Changeable Backing Plate System will allow you to use 4 inch, 5 inch, and 6.5 inch pads with just the three pieces included. (this includes the backing plate included with the unit) Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted May 1, 2014 Share Posted May 1, 2014 That kit includes (gear plate, 4 inch backing plate, 6 inch backing plate) The gear plate is so the two plates are interchangeable, but I yes the Flex still won't take 4" pads. a 4" backing plate (or 4 3/8 as Capt. Phillips told us) would be used with 5.5" pads, a 3" backing plate would be used for 4" pads. The 6 inch plate for 6.5 or 7" pads. Either way your set is awesome but I guess its just two different types of larger backing plates? Link to comment Share on other sites More sharing options...
Fit08
11 answers to this question
