Deery01 Posted August 7, 2015 Share Posted August 7, 2015 My new 2015 platinum has swirl marks from the dealer on the shiny plastic between the windows on the doors. Any ideas for correction? Link to comment Share on other sites More sharing options...
0 Mazzdog Posted August 7, 2015 Share Posted August 7, 2015 There is actually a CG YouTube video about this. I'm sure you could substitute Adams in place of their stuff and get same / better results. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 7, 2015 Share Posted August 7, 2015 Use Revive polish or PCP with a utility MF towel.and that should go the trick..... Link to comment Share on other sites More sharing options...
0 Deery01 Posted August 7, 2015 Author Share Posted August 7, 2015 Ok I'll try the revive. Hope it doesn't make it worse seeing it's a shiny plastic Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 7, 2015 Share Posted August 7, 2015 Ok I'll try the revive. Hope it doesn't make it worse seeing it's a shiny plasticI think you will like the results! ???? Deery01 1 Link to comment Share on other sites More sharing options...
0 vobro Posted August 8, 2015 Share Posted August 8, 2015 (edited) If there's seals exposed make sure to tape them off or they could get stained. Also if you do use a polish do not assume you'd have to use a lot of pressure cause you are doing it by hand, that material is usually softer than regular clear coat Edited August 8, 2015 by vobro Deery01 and mc2hill 2 Link to comment Share on other sites More sharing options...
Deery01
5 answers to this question
