dodgegirl05 Posted November 10, 2015 Share Posted November 10, 2015 I was just wondering if the clay bar and wax is safe for boats? Thank you. Kelly Link to comment Share on other sites More sharing options...
0 rkj4243 Posted November 10, 2015 Share Posted November 10, 2015 Yes, the Adams' products work on boats as well. You may need to ensure the surfaces are properly washed cleaned before using the clay for best results. Link to comment Share on other sites More sharing options...
0 Guest washemup Posted November 10, 2015 Share Posted November 10, 2015 (edited) Boats generally have gel coat on them. Gel coat is more prone to oxidation then common clear coats on vehicles. If your boat is new and has no oxidation, wax will protect the surface, and the clay will remove bonded contaminates. If your boat has light oxidation, clay won't remove it. A gel-coat cleaner wax is what you'll need. For a heavily oxidized boat, it usually requires wet sanding and polishing to remove the oxidation to restore the shine before applying wax. I know this is an Adams forum, but I have to be 100% honest with you. Collinite 925 Boat Wax is designed for gel-coat and is extremely durable. I'd save Americana or Patriot for your vehicles. Edited November 10, 2015 by washemup Link to comment Share on other sites More sharing options...
0 LT1xL82 Posted November 10, 2015 Share Posted November 10, 2015 Boats generally have gel coat on them. Gel coat is more prone to oxidation then common clear coats on vehicles... Is that ever the truth! Many boats also spend more time in the sun than cars. (Agreed, there are many exceptions!) UV protection is really desirable. I have recently found Revive with a blue Hex applicator does a great job cleaning exhaust stains from the fiberglass. Wonder how it would do on light oxidation? Link to comment Share on other sites More sharing options...
0 dodgegirl05 Posted November 10, 2015 Author Share Posted November 10, 2015 I have a friend that's father and the people in his complex live have a bunch of very expensive boats and would like me to clean them? What would you suggest on using? I've never seen them or how long they have been in/out of the water. Link to comment Share on other sites More sharing options...
0 Ashley@Adams Posted November 10, 2015 Share Posted November 10, 2015 I have a friend that's father and the people in his complex live have a bunch of very expensive boats and would like me to clean them? What would you suggest on using? I've never seen them or how long they have been in/out of the water. Our polishes (Paint Correcting and Paint Finishing) actually work great on gel coats. If the surface is heavily oxidized, then polish before you clay. Also, have a couple back up pads, as they can get soiled pretty quickly. From there, definitely go with a Sealant (preferably Liquid Paint Sealant). A sealant will hold up better in the elements. rkj4243 1 Link to comment Share on other sites More sharing options...
0 camaro2ssblack Posted November 10, 2015 Share Posted November 10, 2015 Nope these products don't work on boats... Link to comment Share on other sites More sharing options...
0 dodgegirl05 Posted November 11, 2015 Author Share Posted November 11, 2015 Thank you so much! Link to comment Share on other sites More sharing options...
0 Guest washemup Posted November 11, 2015 Share Posted November 11, 2015 Our polishes (Paint Correcting and Paint Finishing) actually work great on gel coats. If the surface is heavily oxidized, then polish before you clay. Also, have a couple back up pads, as they can get soiled pretty quickly. From there, definitely go with a Sealant (preferably Liquid Paint Sealant). A sealant will hold up better in the elements. Heavy oxidation on a boat cannot be removed with compound alone. Moderate oxidation possibly. Maybe with a heavy cut compound and a wool pad on a rotary, but heavy oxidation most likely will need wet sanding to completely remove, and usually several stages of it. Nope these products don't work on boats... Our polishes (Paint Correcting and Paint Finishing) actually work great on gel coats. If the surface is heavily oxidized, then polish before you clay. Also, have a couple back up pads, as they can get soiled pretty quickly. From there, definitely go with a Sealant (preferably Liquid Paint Sealant). A sealant will hold up better in the elements. Nope these products don't work on boats... Those are nice pics of your Ranger. However, they don't prove anything as far as durability of products used. I like Adams products as much as anyone, if that's what you have on your boat, leave it outside with another for 6 months in the same conditions, going to the same lakes, in the water the same amount of time, with the other product I mentioned on another boat, and then see what the difference is. Link to comment Share on other sites More sharing options...
0 camaro2ssblack Posted November 11, 2015 Share Posted November 11, 2015 Heavy oxidation on a boat cannot be removed with compound alone. Moderate oxidation possibly. Maybe with a heavy cut compound and a wool pad on a rotary, but heavy oxidation most likely will need wet sanding to completely remove, and usually several stages of it. Those are nice pics of your Ranger. However, they don't prove anything as far as durability of products used. I like Adams products as much as anyone, if that's what you have on your boat, leave it outside with another for 6 months in the same conditions, going to the same lakes, in the water the same amount of time, with the other product I mentioned on another boat, and then see what the difference is. You don't have to school me friend, I've been around the block a time or two... And you are absolutely right on most of the things you said... I use an array of products and brands and cater them to my specific needs. I happen not to need durability because my boat stays inside 24/7 and is detailed after each time out of the water. Leave it outside for 6 months?!?! Not a chance lol. Ricky Bobby 1 Link to comment Share on other sites More sharing options...
0 dodgegirl05 Posted November 11, 2015 Author Share Posted November 11, 2015 What if you don't have a buffing wheel? Link to comment Share on other sites More sharing options...
0 Guest washemup Posted November 11, 2015 Share Posted November 11, 2015 (edited) You don't have to school me friend, I've been around the block a time or two... And you are absolutely right on most of the things you said... I use an array of products and brands and cater them to my specific needs. I happen not to need durability because my boat stays inside 24/7 and is detailed after each time out of the water. Leave it outside for 6 months?!?! Not a chance lol. Not my intention at all! Your boat is obviously meticulously maintained judging by the pics! For that I salute you! The response was more for the OP, as she is doing boats for other people. They, I can almost 100% guarantee you, do not take even close to the amount of care of their vessels as you do. Thus the recommendation I gave. I wish I could afford to fish, I haven't even been in a boat since 2008! Detailed a few though. As far as Adams products, I will say the APC rocks on all the really dirty stuff. I've removed mold and stains from vinyl seats that you would think would never come off! What if you don't have a buffing wheel? If you have to work by hand only, your only going to be able to remove light oxidation. Not having seen the boats you are doing, and the condition, I couldn't honestly say if you could fix issues. Edited November 12, 2015 by washemup Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted November 11, 2015 Share Posted November 11, 2015 (edited) Gosh I don't miss having a waverunner - you know what they say about BOATs - Bring Out Another Thousand lol Chase, sharp looking boats my dude! Sealant as a last step FOR SURE on these, whether salt water or not IMO Edited November 11, 2015 by Ricky Bobby Link to comment Share on other sites More sharing options...
0 Guest washemup Posted November 12, 2015 Share Posted November 12, 2015 I think well maintained boats like that catch more fish! An old friend of mine had a Gambler bass boat that he kept in impeccable condition as well, I only fished 2 tourneys with him , I only caught 1 fish each one, but they were both 3lbs plus, and we ended up winning both. I was more worried about bumping his boat or motor with my jig! His motto is "Work is for people who don't know how to fish!" Link to comment Share on other sites More sharing options...
0 crazyzj177 Posted May 26, 2016 Share Posted May 26, 2016 How about a larger boat that never leaves the sun or water? Just got a job for a 4788 bayliner and was curious as to what products would work the best for shine and longevity Link to comment Share on other sites More sharing options...
dodgegirl05
Kelly
14 answers to this question
