After having good results on the Explorer, decided to do the Vette. Its raining and from 45 to 55 degrees. I'm inside garage with overhead door open. Washed outside, dried inside then clayed. C6 black Vette with 90k miles and lots of swirl marks.
Tried test area on hood.. What worked was SHR on orange pad at 5 opm followed with MP on orange pad at 5 opm, wipe off, repeat both of above set at 6 opm, wipe, then apply MP on white pad set at 3 opm. Completed hood then did this over entire Vette. About an hour after finishing hood noticed 3 areas on hood that appeared hazy. One area is at edge of hood below winshield, one is on side of hood near front parallel with fender and the third is a larger area in the middle of the hood ( not quite as hazy).
The area on the hood by the windhield on passenger side was about an inch wide and what appearred to be several areas 2" or so long each. The area on the hood next to the fender on the driver's side was about 2" wide x 8" long. At first I thought these might be due to the weather being damp and cold as I've had that show up on Vettes before after polishing by hand ( especially in the evening you get a dampening of certain areas on these plastic cars) and told myself to leave them alone. However, when finished for the day around 6:30 pm my hands took control...
Tried detail spray on the 8" area. No effect. For the smaller 2" wlde areas grabbed the Revive polish and put in on by hand. When wiped. The areas have now come together and this is now 2" x 8". I have left the area in the middle of the hood alone.
By hazy these areas are just plain blah......dull. Do not feel greasy and they show up more so at certain angles. There has been no sun to view these. Spoke with Leo of Detail Addict on phone yesterday and will likely followup with him. Thought I would run this by the forum to see if any of you have experienced this. Holding off on the wax for now.
xlr8rvette
Sorry this is long and no photos. Thank you
27 answers to this question
