buffalobob920 Posted September 6, 2016 Share Posted September 6, 2016 Detailing a 2006 Dodge Durango it has rubber bumpers on it is there a way to get out swirls and light scratches do you go and correct it the same way as paint thanks with any kind of feed back Link to comment Share on other sites More sharing options...
0 rkj4243 Posted September 6, 2016 Share Posted September 6, 2016 Yes, you can correct and polish them to remove swirls and scratches. A Rupes Mini would be the ideal machine for this small area, or else a Cyclo, and be sure to remove the license plate to prevent any potential mishaps of contacting it with the polisher or pad. Link to comment Share on other sites More sharing options...
0 Green Machine Posted September 6, 2016 Share Posted September 6, 2016 Looks like a magnum? Same way as metal painted parts Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted September 6, 2016 Author Share Posted September 6, 2016 Yes it's a magnum and thanks for the info Link to comment Share on other sites More sharing options...
0 BrianT Posted September 7, 2016 Share Posted September 7, 2016 Just be careful the plastic builds and holds the heat from correcting A LOT more then metal panels, so you may need to adjust your pressure and speed settings. Chris@Adams and Thorsager 2 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted September 7, 2016 Share Posted September 7, 2016 Just be careful the plastic builds and holds the heat from correcting A LOT more then metal panels, so you may need to adjust your pressure and speed settings.Especially if you are using the 4" Focus pads with the drill. Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted September 7, 2016 Author Share Posted September 7, 2016 Thanks guys for all of your input great tips Link to comment Share on other sites More sharing options...
buffalobob920
6 answers to this question
