Ekim716 Posted November 10, 2016 Share Posted November 10, 2016 Trying to get ready for winter, should I wash, clay, then dress the trim? Or wash, dress trim, then clay... does the clay leave residue if I accidentally hit the trim? Link to comment Share on other sites More sharing options...
0 falcaineer Posted November 10, 2016 Share Posted November 10, 2016 (edited) Strip wash, dress trim, then clay, etc. Yes, the clay could leave a residue if you don't..and it still will, probably, but at least it you dress it first it'll be A LOT easier to remove. You can always go back and touch up with VRT at the end just to finish the job, too. Good luck! Edited November 10, 2016 by falcaineer Link to comment Share on other sites More sharing options...
0 Ekim716 Posted November 10, 2016 Author Share Posted November 10, 2016 What should I use to remove it from the trim? Link to comment Share on other sites More sharing options...
0 falcaineer Posted November 10, 2016 Share Posted November 10, 2016 Assuming you mean it has already been dressed with VRT, all you should need is a MF towel to simply wipe it off. I'm sure others may have a recommendation about which one, but I would guess just about any would be ok. It'll come off pretty easily. Link to comment Share on other sites More sharing options...
0 Bryce Posted November 10, 2016 Share Posted November 10, 2016 Are you asking if you need to use a clay bar for your trim? If so, just use VRT. Link to comment Share on other sites More sharing options...
Ekim716
4 answers to this question
