enoch7fa Posted April 10, 2018 Share Posted April 10, 2018 what is ph of strip wash? Link to comment Share on other sites More sharing options...
0 shane@detailedreflections Posted April 10, 2018 Share Posted April 10, 2018 9 minutes ago, enoch7fa said: what is ph of strip wash? It will be on the acidic side. I don’t know as though I’ve ever seen a value published anywhere. Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted April 11, 2018 Share Posted April 11, 2018 I would guess that it would be down around 4, as Detail spray is in the mid 5's and it would need to cut under that. Link to comment Share on other sites More sharing options...
0 TheWolf Posted April 11, 2018 Share Posted April 11, 2018 13 hours ago, enoch7fa said: what is ph of strip wash? I just measured the pH at 13.4 with a little digital meter. This is the pH of the product out of the bottle, and the pH of the washing solution will change depending on how much product is mixed into the wash water, and the pH of your tap water. Products that will strip sealants or waxes (APC), or are used to clean towels are bases, which have high pH. (MFR&B pH=13.4). 3 hours ago, pirahnah3 said: I would guess that it would be down around 4, as Detail spray is in the mid 5's and it would need to cut under that. I recall you have access to real lab equipment, but I just measured the pH of Detail Spray at 6.2. And I had just calibrated the HM Digital meter to 7.0 at 25 degrees C. Note sure how/why the pH would be as low as mid-5. I found your old post when you measured the LIC, but could not find any post for the Detail Spray test. Link to comment Share on other sites More sharing options...
0 shane@detailedreflections Posted April 11, 2018 Share Posted April 11, 2018 36 minutes ago, TheWolf said: Products that will strip sealants or waxes (APC), or are used to clean towels are bases, which have high pH. (MFR&B pH=13.4). Dan, Now you have me confused. I always thought strip washes to be acidic. Even right here in an older Adam’s article, it references APC making the wash acidic. I realize this is an older article, but it seems acids would pull more off than a base would. Just thinking to basic chemistry (which was a LONG time ago so it’s lilely I’ve forgotten and am wrong). Link to comment Share on other sites More sharing options...
0 zw470 Posted April 12, 2018 Share Posted April 12, 2018 Pretty sure someone from Adam's said the reason Strip Wash comes in a different bottle is because the pH is so high. Link to comment Share on other sites More sharing options...
0 TheWolf Posted April 12, 2018 Share Posted April 12, 2018 21 hours ago, shane@detailedreflections said: Dan, Now you have me confused. I always thought strip washes to be acidic. Even right here in an older Adam’s article, it references APC making the wash acidic. I realize this is an older article, but it seems acids would pull more off than a base would. Just thinking to basic chemistry (which was a LONG time ago so it’s lilely I’ve forgotten and am wrong). Acidic products can also strip sealants and waxes, depending on the product and type of protection. I am not sure if the older version of APC referenced in that article was actually acidic, but my guess it was a typo (acidic vs basic). Also, pH is not the only factor in determining whether a product will degrade or strip a wax or sealant. Some products that are solvents will strip without having a pH that is too acidic or too basic. For example, we know Isopropyl Alcohol is effective at striping protection, but the pH can be anywhere from 6-8 depending on the strength and other factors. I just measured the 70% IPA on my shelf and the pH was 7.4. Link to comment Share on other sites More sharing options...
enoch7fa
6 answers to this question
