The world's only handheld vacuum that packs 500 watts of pure power into a 2.7 pound body. Lightweight, portable, convenient, and incredible suction!
Adam's Vac N' Blo 500 Handheld Vacuum, by MetroVac, is based on the original 200 watt handheld vacuum they started manufacturing in 1957. They were the first company to produce a handheld vacuum, and they are the only company to create a small car vacuum with such incredible power. Compared to the Vac N' Blo 500, all other handheld vacuums are mere toys.
Adam's Vac N' Blo 500 by MetroVac features a state-of-the-art fan enclosed motor that cranks out more than 55 inches of water lift while pulling only 4.5 amps of power. In case you're wondering, an excellent full-size household vacuum can generate around 70 inches of water lift. Not only does the Vac N' Blo 500 comes closer to the power of a full size than any other handheld vacuum, it's also got more attachments and it's super durable. While all other handheld vacuums are constructed with cheap plastics, the American made Vac N' Blo 500 has a rolled steel body construction for a lifetime of use.
* The Vac N' Blo 500 has 55+ inches of water lift to thoroughly clean carpet, upholstery and floor mats.
* The Vac N' Blo 500 uses standard 110 volt power, not batteries.
* The Vac N' Blo 500 includes a 3 foot host, crevice tool and dust brush.
* The Vac N' Blo 500’s compact design makes it ideal for your RV or office, too!
Specifications:
- 500 watts
- State-of-the-art fan enclosed motor
- 110 volts power at 4.5 amps
- All steel construction
- Powerful 55+ inches of water lift
- Includes 3 foot hose, crevice tool and dusting brush
Team Adam's
Adam's Vac N' Blo 500 Handheld Vacuum by MetroVac
Specifications:
- 500 watts
- Made in the USA
- 5 year motor warranty
http://www.adamspolishes.com/p-398-adams-vac-n-blo-500-by-metro-vac.aspx
10 answers to this question
