J-Will Posted June 8, 2018 Share Posted June 8, 2018 Can the trim coating kit be used to provide longer protection to the plastics under the hood such as engine cover, battery cover, etc? Link to comment Share on other sites More sharing options...
1 ZMAN024 Posted June 8, 2018 Share Posted June 8, 2018 Absolutely. As a matter of fact, the original promo pics for the Trim Coating show it being applied to an engine cover, so go right ahead. Link to comment Share on other sites More sharing options...
0 moons21 Posted June 8, 2018 Share Posted June 8, 2018 1 hour ago, ZMAN024 said: Absolutely. As a matter of fact, the original promo pics for the Trim Coating show it being applied to an engine cover, so go right ahead. I thought the pic you are referring to was the trim restorer not the trim ceramic coating.. Since the Coating (Ceramic) is only what.. 4h, would that hold up to the heat under a hood? Wheel coating is designed for high heat so not sure... Link to comment Share on other sites More sharing options...
0 falcaineer Posted June 8, 2018 Share Posted June 8, 2018 6 hours ago, moons21 said: I thought the pic you are referring to was the trim restorer not the trim ceramic coating.. Since the Coating (Ceramic) is only what.. 4h, would that hold up to the heat under a hood? Wheel coating is designed for high heat so not sure... The new coatings are all 9H. Link to comment Share on other sites More sharing options...
0 ZMAN024 Posted June 9, 2018 Share Posted June 9, 2018 7 hours ago, moons21 said: I thought the pic you are referring to was the trim restorer not the trim ceramic coating.. Since the Coating (Ceramic) is only what.. 4h, would that hold up to the heat under a hood? Wheel coating is designed for high heat so not sure... You are correct. My bad on the pic reference, but I see no reason why the Ceramic Trim Coating couldn't be applied under the hood. Link to comment Share on other sites More sharing options...
J-Will
4 answers to this question
