New Detail Sponges Needed
I just ordered your 4" buffing pads and love them. But I think something else is needed. We need a small, preferably cone shaped pad, on an extension for a drill that can reach the hard to reach areas under the hood, and behind the wheel spokes.
I have the competitiors P-Ball and Cone. The 1st is the wrong shape and the second is the wrong size and cannot reach tighter areas. Also the comps product is not near as solid or the quality of your pads.
Areas that I have trouble reaching. Polished maniford under the air cleaner. / Grooves in the milled surface of the valve covers and air cleaner. / Chrome water pump / chrome pulleys / tight grooves in the export brace / recessed areas of dash and grill.
A miniture cone with a firm tip on an extention would be perfect. If only one texture, the white pad texture would be prefered, but wouldnt mind one in each grit.
The product that you offer for polishing wheels I am afraid will tangle with hoses and wires under the hood.
Reply to this topic...
 Share
