acrispy1 Posted November 9, 2009 Share Posted November 9, 2009 What is the best way to remove window tint? Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted November 9, 2009 Share Posted November 9, 2009 That is a good question! I would google it, let us know ! Link to comment Share on other sites More sharing options...
0 GXPimpin Posted November 9, 2009 Share Posted November 9, 2009 peel back a corner with a razor blade then slowly pull it off like a giant sticker.... then the fun part allot of soapy water on the glue residue and use the Razor blade to scrape it off being careful not to scratch. Link to comment Share on other sites More sharing options...
0 JJ1o87 Posted November 9, 2009 Share Posted November 9, 2009 The best way to do it is to have someone else do it lol Link to comment Share on other sites More sharing options...
0 694doorbird Posted November 9, 2009 Share Posted November 9, 2009 peel back a corner with a razor blade then slowly pull it off like a giant sticker.... then the fun part allot of soapy water on the glue residue and use the Razor blade to scrape it off being careful not to scratch. Either that or take it to a tint shop. Link to comment Share on other sites More sharing options...
0 dabigbratj Posted November 10, 2009 Share Posted November 10, 2009 tint place should only cost like 30-40 and well worth it.cause it is a pain Link to comment Share on other sites More sharing options...
0 70'sChevyGirl Posted November 10, 2009 Share Posted November 10, 2009 My husband is a body tech and he said to use window cleaner with alot of ammonia in it. Spray it and let it sit for about 5 minutes and then get a plastic scraper and get the glue off. He said the ammonia will cut thru the glue. Then when your all done getting the yucky stuff off you grab your bottle of Adam's Glass Cleaner and make them all nice and shiny again. Link to comment Share on other sites More sharing options...
0 11chevz71 Posted November 10, 2009 Share Posted November 10, 2009 Hmm i need to get my front windows tinted like my back windows on my truck. Link to comment Share on other sites More sharing options...
0 jjwvette Posted November 10, 2009 Share Posted November 10, 2009 The best way to do it is to have someone else do it lol Good answer... Link to comment Share on other sites More sharing options...
0 jnf Posted November 11, 2009 Share Posted November 11, 2009 The best way is to "sweat" it off. Take some black trash bags and cut them to fit each window that you would like to remove. Next, spray the window with Windex getting quite wet with the solution. Next while the glass is wet, apply the black plastice over the glass. Make sure there is enough windex between the bag and the glass. Move vehicle into the sunlight for 1 to 2 hours. At that point, you should be able to remove the tint and adhesive in the same motion, by grabbing the top corner and pulling it off the glass. If it doesn't come easily, it hasn't sweated enough. Link to comment Share on other sites More sharing options...
0 jjwvette Posted November 11, 2009 Share Posted November 11, 2009 The best way is to "sweat" it off.Take some black trash bags and cut them to fit each window that you would like to remove. Next, spray the window with Windex getting quite wet with the solution. Next while the glass is wet, apply the black plastice over the glass. Make sure there is enough windex between the bag and the glass. Move vehicle into the sunlight for 1 to 2 hours. At that point, you should be able to remove the tint and adhesive in the same motion, by grabbing the top corner and pulling it off the glass. If it doesn't come easily, it hasn't sweated enough. Learn something new again.... Link to comment Share on other sites More sharing options...
0 whiterp199 Posted November 12, 2009 Share Posted November 12, 2009 Learn something new again.... I had never heard of that method either. Link to comment Share on other sites More sharing options...
0 becand75 Posted November 12, 2009 Share Posted November 12, 2009 The best way is to "sweat" it off.Take some black trash bags and cut them to fit each window that you would like to remove. Next, spray the window with Windex getting quite wet with the solution. Next while the glass is wet, apply the black plastice over the glass. Make sure there is enough windex between the bag and the glass. Move vehicle into the sunlight for 1 to 2 hours. At that point, you should be able to remove the tint and adhesive in the same motion, by grabbing the top corner and pulling it off the glass. If it doesn't come easily, it hasn't sweated enough. I've never heard of this method before. Hmmmm. I know from experience that removing tint is pretty tedious and takes alot of time to do it right. The problem isn't getting the tint off, its getting all the adhesive off. I can still remember spending hours with adhesive remover and a razor blade getting the tint off of an older car of mine. I'd probably just have a professional do it if I had to do it again. Link to comment Share on other sites More sharing options...
acrispy1
12 answers to this question
