Goatman06 Posted May 23, 2010 Share Posted May 23, 2010 Just like the title, i just used some similar product it had great results but, it dusted quite a bit does the SHR dust? i was thinking about trying it. its pretty much the only adams product i dont have...lol thanks Link to comment Share on other sites More sharing options...
Junkman2008 Posted May 26, 2010 Share Posted May 26, 2010 Thanks Junkman, thanks for taking the time to post your vids, i learn alot and have a good time watching them. by watching you i seem to have been using to much product. my qestion is do you use your 3 pea size drops on each panel or do you just re prime the pad with detail spray and work the existing product as far as it will get you on the next panel? I also think im working to big a area also. i will do like half of the hood at once, i think this is to much and causing the products to dry quicker since im working in to large a area? am i correct? thanks for your time. Bob Whoa, half a hood? The only way you should be doing half a hood with one application is on this puppy! There is no possible way that you can be having any success, working on an area that large. That will spread the product way too thin causing you to use way to much product. And yes, it will dry up very fast, especially if you are working in the sun. When I use 3 pea-sized drops, I do so for a 1.5' - 2' area, NOT per panel. I break every panel up into sections and work each section until I am satisfied with the results on that section. I may spend hours on a entire panel if it is in that bad of shape. For me, it's not about getting it done, it's about getting it right. You definitely need to decrease the size area that you're working and concentrate on your technique (not going to fast or using too much product). Take a look at my "From Clay to Wax" series and look at the size area I work. That video series explains it all. Link to comment Share on other sites More sharing options...
Chris@Adams Posted July 1, 2010 Share Posted July 1, 2010 You will probably find that you are using too much product! Link to comment Share on other sites More sharing options...
srthemi Posted June 30, 2010 Share Posted June 30, 2010 If you search for dusting, you'll probably get better results. Take a look at the following thread. This should help you out. http://www.adamsforums.com/forums/showthread.php?t=6919&highlight=dusting Thanks, I knew I saw it somewhere. I didn't use dusting in my search, I used powder. My bad. Greg. Link to comment Share on other sites More sharing options...
Sooners Posted June 30, 2010 Share Posted June 30, 2010 If you search for dusting, you'll probably get better results. Take a look at the following thread. This should help you out. http://www.adamsforums.com/forums/showthread.php?t=6919&highlight=dusting Link to comment Share on other sites More sharing options...
srthemi Posted June 30, 2010 Share Posted June 30, 2010 I know I've seen this before but can't find it using the search function. When using SHR or FMP by PC should you get some powder? And if you do, does that mean you are polishing to long? Thanks. Greg. Link to comment Share on other sites More sharing options...
Nordgrey Posted May 27, 2010 Share Posted May 27, 2010 Hmmmm, glass sealant anyone? I too did the too much product/not enough DS thing the first time out. Livin' and learnin'!! Link to comment Share on other sites More sharing options...
gonz0 Posted May 27, 2010 Share Posted May 27, 2010 Ooops... i was using a lil too much also. I now have a bit more understanding of what to do. It seems like know matter how good ur videos are we still find a way come up with some unanswered questions. Link to comment Share on other sites More sharing options...
Team Adam's Posted May 26, 2010 Share Posted May 26, 2010 Agreed, dusting will be at a minimum... generally you'll only see it if you take the pad across a gap or edge and the pad throws out some spent polish. You also might see it if you were to lift an edge or have the pad in less than flush contact with a panel. Link to comment Share on other sites More sharing options...
Junkman2008 Posted May 26, 2010 Share Posted May 26, 2010 lol thanks junkman for the help... i can't wait to try it out. Link to comment Share on other sites More sharing options...
Goatman06 Posted May 26, 2010 Author Share Posted May 26, 2010 Whoa, half a hood? The only way you should be doing half a hood with one application is on this puppy! There is no possible way that you can be having any success, working on an area that large. That will spread the product way too thin causing you to use way to much product. And yes, it will dry up very fast, especially if you are working in the sun. When I use 3 pea-sized drops, I do so for a 1.5' - 2' area, NOT per panel. I break every panel up into sections and work each section until I am satisfied with the results on that section. I may spend hours on a entire panel if it is in that bad of shape. For me, it's not about getting it done, it's about getting it right. You definitely need to decrease the size area that you're working and concentrate on your technique (not going to fast or using too much product). Take a look at my "From Clay to Wax" series and look at the size area I work. That video series explains it all. lol thanks junkman for the help... i can't wait to try it out. Link to comment Share on other sites More sharing options...
Goatman06 Posted May 26, 2010 Author Share Posted May 26, 2010 Allow me to tweak your answer a bit. SHR will NOT dust up if you do not use too much product AND you are using thoroughly cleaned pads. If you take a brand new pad and start seeing dusting, then you are using too much product OR you are working on surface that is too hot. If the surface is too hot, move the car out of direct sunlight or start implementing more detail spray onto the pads. Big chunks of flaking product is a real good sign of too much product on a saturated paid. If the dusting is extremely fine, then you're working with a pad that you didn't get completely clean when you last washed it. Again, more detail spray will help control that but you need to do a better job cleaning your pads. That's why I do it this way. Thanks Junkman, thanks for taking the time to post your vids, i learn alot and have a good time watching them. by watching you i seem to have been using to much product. my qestion is do you use your 3 pea size drops on each panel or do you just re prime the pad with detail spray and work the existing product as far as it will get you on the next panel? I also think im working to big a area also. i will do like half of the hood at once, i think this is to much and causing the products to dry quicker since im working in to large a area? am i correct? thanks for your time. Bob Link to comment Share on other sites More sharing options...
Junkman2008 Posted May 26, 2010 Share Posted May 26, 2010 Yes, SHR will dust. However, if you're getting excessive dust, it's because you're using too much product. If you use the proper amount and keep the pad primed, the dusting will be minimal. Allow me to tweak your answer a bit. SHR will NOT dust up if you do not use too much product AND you are using thoroughly cleaned pads. If you take a brand new pad and start seeing dusting, then you are using too much product OR you are working on surface that is too hot. If the surface is too hot, move the car out of direct sunlight or start implementing more detail spray onto the pads. Big chunks of flaking product is a real good sign of too much product on a saturated paid. If the dusting is extremely fine, then you're working with a pad that you didn't get completely clean when you last washed it. Again, more detail spray will help control that but you need to do a better job cleaning your pads. That's why I do it this way. Link to comment Share on other sites More sharing options...
lawson4450 Posted May 23, 2010 Share Posted May 23, 2010 I bought a stiff bristle brush used to wash the pads from another site and instead i use it to clean the pad occasionally while i use it. I use it with some product and then i use the pad with some DS and after like half the car i run the brush over the pad and it opens up the poors on the pad and works great. It cuts down the dusting and over use of product off the pad. I only use it once or twice and im good. Link to comment Share on other sites More sharing options...
Goatman06 Posted May 23, 2010 Author Share Posted May 23, 2010 i was just watching junkman vids, i love them. but anyway im deffinatly using to much product and clogging up my pads wich is making my dust. thanks alot for the help i appreciate it.. Link to comment Share on other sites More sharing options...
Chris@Adams Posted May 23, 2010 Share Posted May 23, 2010 i always prime the bad before i use it, do you prime the pad more than once? to be honest when i move to the next panel i always put more product on,not a ton but some,to work the next section, i shouldnt be doing this? Bob, Every once in a while skip product and just spray a spray or two of DS. Link to comment Share on other sites More sharing options...
Goatman06 Posted May 23, 2010 Author Share Posted May 23, 2010 i always prime the bad before i use it, do you prime the pad more than once? to be honest when i move to the next panel i always put more product on,not a ton but some,to work the next section, i shouldnt be doing this? Link to comment Share on other sites More sharing options...
Chris@Adams Posted May 23, 2010 Share Posted May 23, 2010 Yes, SHR will dust. However, if you're getting excessive dust, it's because you're using too much product. If you use the proper amount and keep the pad primed, the dusting will be minimal. Less is more with product! Link to comment Share on other sites More sharing options...
Sooners Posted May 23, 2010 Share Posted May 23, 2010 Yes, SHR will dust. However, if you're getting excessive dust, it's because you're using too much product. If you use the proper amount and keep the pad primed, the dusting will be minimal. Link to comment Share on other sites More sharing options...
Goatman06
18 answers to this question
