Neil Broeker Posted July 23, 2010 Share Posted July 23, 2010 Good morning from Indiana. I discovered last night that I ran out of Detail Spray. I htought I had another gallon, but was mistaken. Question I have is what can I use instead of Detail Spray for clay barring a vehicles. Thnaks Link to comment Share on other sites More sharing options...
Chewy Posted July 23, 2010 Share Posted July 23, 2010 A mix of Adams shampoo and water... An 80/20 mix. Water/soap should suffice. Chris Link to comment Share on other sites More sharing options...
Chris@Adams Posted July 23, 2010 Share Posted July 23, 2010 Or you use WCW in a pinch, it might take more rubbing and more pressure though.Because the WCW is so slick. Link to comment Share on other sites More sharing options...
Marylander Posted July 23, 2010 Share Posted July 23, 2010 Hi Niel - Welcome to Adam's. You'll find there's lots of good, fast advice to be found here -- I'm sure you'll enjoy the site. Any of the above DS substitute solutions should work well for you. Rich Link to comment Share on other sites More sharing options...
GTO Guy Posted July 23, 2010 Share Posted July 23, 2010 soap and water. it is what i used before i knew about DS! Link to comment Share on other sites More sharing options...
The Ryan Posted July 23, 2010 Share Posted July 23, 2010 As with everyone else.. I actually used it today 7:1 - water:shampoo. Adam's shampoo has great lubricity. If you use too much soap you won't get all the contamination off the paint because the soap is so dang slick! Easy way to do it, 2oz of soap in the bottom of the 16oz bottle, fill with water - perfect 7:1 ratio. Anything more than 6:1 ratio will be way to slick for a clay lube. Link to comment Share on other sites More sharing options...
Neil Broeker
5 answers to this question
