I would like input on what should be done if the pad you are using on the PC appears to get "dirty". This is after properly washing, drying, claying and starting with the yellow pad. What SHOULD be done. Continue the process of SHR, FMP, and MSW; wiping down between each step or only continue the SHR, wipe down, clean the yellow pad and start over?
VertimgoC502
11 answers to this question
