PeteH Posted April 4, 2011 Share Posted April 4, 2011 ......... Link to comment Share on other sites More sharing options...
PeteH Posted April 8, 2011 Author Share Posted April 8, 2011 .............. Link to comment Share on other sites More sharing options...
PeteH Posted April 10, 2011 Author Share Posted April 10, 2011 ...... Link to comment Share on other sites More sharing options...
trashauler Posted April 10, 2011 Share Posted April 10, 2011 WD40 or PB Blaster work great for removing tar Link to comment Share on other sites More sharing options...
H&R Posted April 10, 2011 Share Posted April 10, 2011 Wife had some on the rocker panels of her car,sprayed apc on it and it whiped off.then i reapplied wax to those areas. Link to comment Share on other sites More sharing options...
Vincenzo Posted April 10, 2011 Share Posted April 10, 2011 It's not an end all save all, but it's probably the best product they make! lol Too bad the 3M stuff is obsolete. I'm sure someone online has it. Sent from my iPad using special algorithms and data nodes. Lol that's true. I've tried several of their products and none work at all. I can't wait for Adam's Bug and Tar Remover. Link to comment Share on other sites More sharing options...
1anonly Posted April 9, 2011 Share Posted April 9, 2011 Motorcraft makes some stuff you can buy at a Ford dealership. It's not as good the 3M stuff, but not bad. I found the 3M in a spray at Advanced Autos yesterday. Link to comment Share on other sites More sharing options...
Chewy Posted April 9, 2011 Share Posted April 9, 2011 I don't know if the stuff they put on roads out here is different from where you are Chewy, but I have had no success whatsoever with that brand. And the nozzle keeps getting jammed. It's not an end all save all, but it's probably the best product they make! lol Too bad the 3M stuff is obsolete. I'm sure someone online has it. Sent from my iPad using special algorithms and data nodes. Link to comment Share on other sites More sharing options...
Vincenzo Posted April 9, 2011 Share Posted April 9, 2011 I don't know if the stuff they put on roads out here is different from where you are Chewy, but I have had no success whatsoever with that brand. And the nozzle keeps getting jammed. Link to comment Share on other sites More sharing options...
PeteH Posted April 8, 2011 Author Share Posted April 8, 2011 ...... Link to comment Share on other sites More sharing options...
Chewy Posted April 8, 2011 Share Posted April 8, 2011 I hate to say it, but that really slow animal with a shell company has a REALLY good tar/bug remover as well. Link to comment Share on other sites More sharing options...
Odds and Ends Posted April 8, 2011 Share Posted April 8, 2011 Since I just ran out, I tried to restock my 3M adhesive remover yesterday at my auto body supply house and they (3M) have discontinued it. There are other comparable solvents out there. Personally, for tar removal, I use XENIT. It is a citrus based aerosol and the tar spots literally drip/run off the car. Doubt you will find it in stores. - Darryl Link to comment Share on other sites More sharing options...
Bert Posted April 5, 2011 Share Posted April 5, 2011 I personally use 3M Adhesive remover. It's quick and auto body safe. ^That or Tarminator. A body solvent would probably work also and a body solvent can be used for other purposes also. What ever you use, as someone said, if it is strong it enough to remove the tar, it will easily remove your wax or sealant. Link to comment Share on other sites More sharing options...
Bill-V8V Posted April 4, 2011 Share Posted April 4, 2011 Hopefully sometime we will have Adam's Tar Remover!! I wouldn't be surprised if there was something in the works Link to comment Share on other sites More sharing options...
SinlessVillainy Posted April 4, 2011 Share Posted April 4, 2011 I personally use 3M Adhesive remover. It's quick and auto body safe. I just use a Adams MF applicator. Chris That stuff is awesome. We used it to remove the adhesive residue left behind by pinstriping on a buddy's Wrangler. It took it off in a breeze. Then when I baked my headlights and took them apart to retrofit the projectors, I accidentally got some adhesive on the outside of the lens. That 3M Adhesive remover took it right off with minimal effort. Link to comment Share on other sites More sharing options...
THE Mook Posted April 4, 2011 Share Posted April 4, 2011 I was able to get off tar and road paint with a plastic razor blade and APC. Link to comment Share on other sites More sharing options...
Chris@Adams Posted April 4, 2011 Share Posted April 4, 2011 Hopefully sometime we will have Adam's Tar Remover!! Link to comment Share on other sites More sharing options...
Chewy Posted April 4, 2011 Share Posted April 4, 2011 I wonder if WW would work if you let it soak for a while? Or do you need a petroleum based product. Dylan? Waterless wash? NO WAY! Citrus based will work too. Keep in mind, tar removers REMOVE wax too. Chris Link to comment Share on other sites More sharing options...
musclejunkie Posted April 4, 2011 Share Posted April 4, 2011 I wonder if WW would work if you let it soak for a while? Or do you need a petroleum based product. Dylan? Link to comment Share on other sites More sharing options...
Chewy Posted April 4, 2011 Share Posted April 4, 2011 I personally use 3M Adhesive remover. It's quick and auto body safe. I just use a Adams MF applicator. Chris Link to comment Share on other sites More sharing options...
Kustom_FX Posted April 4, 2011 Share Posted April 4, 2011 Well I used Dylans trick on burnt rubber on that and tar and it seemed to work. APC and a Pressure Washer.. Soaked it with APC at the quarter wash then blasted it off, then I took it home and 2 bucket washed it and threw some wax on the lower half. Hope this helps! Link to comment Share on other sites More sharing options...
PeteH
20 answers to this question
