jem556 Posted May 13, 2011 Share Posted May 13, 2011 I have never used Adams products before (possible Griot's convert here ). Does one need to be careful about getting the Machine Super Wax on black plastic parts, ie does it leave residue? TIA Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted May 13, 2011 Share Posted May 13, 2011 Like mentioned above, if you get wax on any plastic it easily comes off with a little APC. A wash after claying isn't necessary, but you could if you want to. I personally don't wash after a clay! Have fun, take some before and after shots Link to comment Share on other sites More sharing options...
MAYBEN Posted May 15, 2011 Share Posted May 15, 2011 Putting them in a sealed bag for a few hours (like you can do with a paint brush/roller) should be fine. Keeps them from drying out. Get yourself a bucket ready for the pads when you're done. Put a little APC in the water, and toss the pads in to soak (I put the Grit Guard on top of the pads to keep them from floating). However, once the pads are cleaned, DO NOT put them in a sealed container until they are completely dry. also put the bag and pads in the fridge, I believe that helps too.. Link to comment Share on other sites More sharing options...
mc2hill Posted May 14, 2011 Share Posted May 14, 2011 Ok, I was up late doing a little polishing.. I did not was my pads last night because I knew I would be back at it this am, I did however put them in a plastic bag.... Is there a problem with using these or should I get the new ones out till I get these washed? Sorry for the NuB questions.. Putting them in a sealed bag for a few hours (like you can do with a paint brush/roller) should be fine. Keeps them from drying out. Get yourself a bucket ready for the pads when you're done. Put a little APC in the water, and toss the pads in to soak (I put the Grit Guard on top of the pads to keep them from floating). However, once the pads are cleaned, DO NOT put them in a sealed container until they are completely dry. Link to comment Share on other sites More sharing options...
Z06Addict Posted May 14, 2011 Share Posted May 14, 2011 Ok, I was up late doing a little polishing.. I did not was my pads last night because I knew I would be back at it this am, I did however put them in a plastic bag.... Is there a problem with using these or should I get the new ones out till I get these washed? Sorry for the NuB questions.. Link to comment Share on other sites More sharing options...
BRZN Posted May 14, 2011 Share Posted May 14, 2011 I don't wash after the clay bar session. The pads, for polish, are primed with DS. I really don't see the need for that extra step in an already lengthy process. Welcome, and post pics when done! Link to comment Share on other sites More sharing options...
MAYBEN Posted May 14, 2011 Share Posted May 14, 2011 welcome Jim, and post pics of that Tahoe! Link to comment Share on other sites More sharing options...
jem556 Posted May 13, 2011 Author Share Posted May 13, 2011 Thanks to all for the feedback...I am going to try the MSW and BG on my dark green metallic Tahoe. Link to comment Share on other sites More sharing options...
Chewy Posted May 13, 2011 Share Posted May 13, 2011 Thanks! I Guess it's ok to leave the residue of the ds on over night after claying if need be? I would imagine as long as it's inside it wouldn't matter much. Put it this way, I have not had any issues doing it that way. Agreed! Dust DOES like to settle though so be aware of that. Chris Link to comment Share on other sites More sharing options...
Bigredmariner Posted May 13, 2011 Share Posted May 13, 2011 Thanks! I Guess it's ok to leave the residue of the ds on over night after claying if need be? I would imagine as long as it's inside it wouldn't matter much. Put it this way, I have not had any issues doing it that way. Link to comment Share on other sites More sharing options...
Z06Addict Posted May 13, 2011 Share Posted May 13, 2011 Make sure if you're doing a paint correction to tape off the plastic bits or places you don't want polish to go. Good luck! Chris Thanks! I Guess it's ok to leave the residue of the ds on over night after claying if need be? Link to comment Share on other sites More sharing options...
Chewy Posted May 13, 2011 Share Posted May 13, 2011 Sounds good, getting started on the clay tonight.. the plan is to polish tomorrow, just read about the residue that is possible and it freaked me out a lil. I plan on having the laptop close by and follow the Junk Man:bow: Make sure if you're doing a paint correction to tape off the plastic bits or places you don't want polish to go. Good luck! Chris Link to comment Share on other sites More sharing options...
Z06Addict Posted May 13, 2011 Share Posted May 13, 2011 Sounds good, getting started on the clay tonight.. the plan is to polish tomorrow, just read about the residue that is possible and it freaked me out a lil. I plan on having the laptop close by and follow the Junk Man:bow: Link to comment Share on other sites More sharing options...
Chewy Posted May 13, 2011 Share Posted May 13, 2011 If you leave it on there it will dry and show the residue, but if you wipe it off fresh you'll be fine. It's great stuff! Oh and welcome! I've used some G brand in the past and IMO the customer support here is MUCH better. Chris Link to comment Share on other sites More sharing options...
Bigredmariner Posted May 13, 2011 Share Posted May 13, 2011 Brandon, no need to wash between polish and machine super wax. Link to comment Share on other sites More sharing options...
Z06Addict Posted May 13, 2011 Share Posted May 13, 2011 Question..... I have read that you should wash the car after the clay bar before you begin to polish.... should you wash again after the polish before the ms wax Link to comment Share on other sites More sharing options...
Chris@Adams Posted May 13, 2011 Share Posted May 13, 2011 No nothing that won't wipe off! Link to comment Share on other sites More sharing options...
jem556
16 answers to this question
