BlueGenCoupe Posted September 10, 2011 Posted September 10, 2011 A friend was driving and drove over fresh paint. He got yellow paint all over his wheel well and on some panels. I remember a while ago there was a thread on it but I can't find it. How can I go about removing this?
LDM Posted September 10, 2011 Posted September 10, 2011 Is this the thread you were looking for? http://www.adamsforums.com/forums/tips-tricks/8940.htm
07RS4 Posted September 11, 2011 Posted September 11, 2011 Well, if there is a bright side, it's on a very durable surface that you can work with and not enflict much damage. Laquer thinner, commercial paint thinner, APC, or even carb cleaner might cut it. Depends on the type of paint, but it's probably oil based and not water based. Just be sure to try a small area, but those shouldn't do any damage to the fenderwell plastic. If there is any on the paint that thread should help. I've got a box of a hundred plastic razor blades that might do the trick, but that wouldn't help you.
Rich Posted September 11, 2011 Posted September 11, 2011 I did that with the Vette a while back. Soon as I got home I started hitting it with Detail Spray and it took it all off. Took some muscle, but it took it all off.
BlueGenCoupe Posted September 11, 2011 Author Posted September 11, 2011 Should I try some DS and clay first? or spray the area with APC and elbow grease? or paint thinner/lacquer?
07RS4 Posted September 11, 2011 Posted September 11, 2011 Should I try some DS and clay first?or spray the area with APC and elbow grease? or paint thinner/lacquer? Least aggressive IMO...if it worked for someone with DS and clay, then try that first. No reason to go full out if you don't have to.
Chris@Adams Posted September 11, 2011 Posted September 11, 2011 Good luck & report back what method worked!
BlueGenCoupe
6 answers to this question
