deltakilo Posted March 8, 2012 Share Posted March 8, 2012 Hey guys I'm currently using SHR for my first time and getting a lot of orange dust... dried Polish I guess all over. The paint looks great but now its dusted with this!!!! Thanks in advance Sent from my ADR6400L using Tapatalk Link to comment Share on other sites More sharing options...
07RS4 Posted March 8, 2012 Share Posted March 8, 2012 What's the question Dan? Link to comment Share on other sites More sharing options...
Tim Posted March 8, 2012 Share Posted March 8, 2012 You may be using too much polish. Hit up with detail spray and work without applying more polish for a while. Link to comment Share on other sites More sharing options...
deltakilo Posted March 8, 2012 Author Share Posted March 8, 2012 That makes sense. I do see some buildup in the center of the pad. Now for FMP... but it looks so good now! Can I just use sealant now? Sent from my ADR6400L using Tapatalk Link to comment Share on other sites More sharing options...
Team Adam's Posted March 8, 2012 Share Posted March 8, 2012 Dusting is a common symptom of using too much product. Move to the next panel but just give the pad 2 sprays of detail spray without adding more polish. Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted March 8, 2012 Share Posted March 8, 2012 Definitly too much polish. Less polish more DS Link to comment Share on other sites More sharing options...
goheels Posted March 8, 2012 Share Posted March 8, 2012 That makes sense. I do see some buildup in the center of the pad. Now for FMP... but it looks so good now! Can I just use sealant now? Sent from my ADR6400L using Tapatalk I assume from the smiley that you aren't being serious, but just in case... definitely don't skip the FMP step as it cleans up the microscratching from the SHR. Link to comment Share on other sites More sharing options...
dipolley Posted March 8, 2012 Share Posted March 8, 2012 Swirl and haze, fine machine, wipe off polish, then sealent. For an even deeper shine and more protection apply Brilliant Glaze over the sealent, then Americana or Buttery wax over the BG. You will love the results. Link to comment Share on other sites More sharing options...
deltakilo Posted March 9, 2012 Author Share Posted March 9, 2012 Thanks for the help guys, it looks fantastic! minus the dusting, I guess i've just never seen a video on how much product to use on a new panel, but now I can just use common sense, if its dusting, use less dummy! Snapped only one shot before finishing Was hoping i could use the full moon for some excellent shots but its overcast:mad: Link to comment Share on other sites More sharing options...
dipolley Posted March 9, 2012 Share Posted March 9, 2012 3 pea sized drops will do you just fine after the first pass. USE LESS PRODUCT, DUMMY!!! Link to comment Share on other sites More sharing options...
Doug123 Posted March 9, 2012 Share Posted March 9, 2012 If you are getting dusting, hold off on the product, just give the pad one spray with DS and just polish a 2x2' pass with that. When you give the pad a squirt of DS, it 'wakes up' some of the polish in the pad. I alternate when polishing - 1pass@3 quarter inch drops on the pad, one pass with DS, etc. etc. You don't want too little polish, nor too much polish. The pad does part of the work, so if it clogs up with polish, it actually slows down the correction. Too much polish is a common mistake- I did that my first polishing session. And, if you think it looks good after the SHR, wait until you see the results of FMP. The more I use FMP, the more impressed I am with it. After you wipe off the FMP, the finish is just stunning. Link to comment Share on other sites More sharing options...
deltakilo
10 answers to this question
