Like tires that look new, not oily and shiny? How about the exterior plastic of your vehicle? You will love our Vinyl, Rubber, and Tire Dressing. Enhance and protect the appearance of plastic, rubber, tires, moldings, and all vinyl surfaces. Adam’s V.R.T. is water-based, and contains no harmful solvents or alcohol. The thick moisturizing cream applies easily with a sponge and will not leave a greasy film, attract dirt, or harm paint and glass. Added U.V. protection keeps vehicle interiors and exteriors looking and feeling like new.
FAQ's & Instructions for Adam's Vinyl, Rubber, & Tire Dressing:
I have many plastic, rubber, and vinyl trim pieces on my vehicle that are faded. What product(s) do you offer that well help restore and protect my oxidized trim pieces back to new?
Adam’s offer two products to shine and protect plastic, rubber, and vinyl. VRT (Vinyl, Rubber and Tire) Protectant and In & Out Spray. Both are completely safe, so there is no fear of damage to painted surfaces will not discolor like similar alcohol and heavy-silicone-based dressings and leave a nice matte finish that does not attract dust or dirt.
How to Apply VRT:
Start with a clean, dry surface. Since VRT is water-based it will NOT adhere to areas that are still wet or damp. Using a detail sponge, squirt a quarter sized amount of VRT in to the center. Squeeze the sponge on both sides so that the VRT can spread out and soak in to the applicator (this will ensure even coverage). Rub vigorously over the surfaces you wish to protect. Add more VRT for proper coverage or for a shiner look if desired.
How to use In & Out Spray
Like the VRT, In & Out is water-based and will not adhere if areas are damp or wet. Simply spray on the areas you wish to add instant shine. (Tip – Instead of spraying one continuous stream of product, lightly tap the sprayer head as you will apply the dressing more evenly using less product.) Consult our detailing videos to see how this is done.
Team Adam's
VRT
http://www.adamspolishes.com/p-101-vrt-vinyl-rubber-tire-dressing-16oz.aspx
How to Apply VRT:
Use VRT:
Tires
Unpainted plastic Mirrors
Tonneau Covers
Bumper step covers
Fender flairs
Vinyl Tops
Use In & Out Spray:
Plastic Wire covers (Engine)
Vents
Unpainted Plastic Door Handles
Hoses (Engine)
Cowl Area
Windshield Wipers & Arms
Want more info? Click the PLAY button on the videos Here: http://www.adamspolishes.com/t-Videos_DVD5_13.aspx
13 answers to this question
