DemoN Posted June 21, 2012 Share Posted June 21, 2012 I’m looking at floor shifter options for the truck. I’m gonna start the console build, AGAIN, in the next month or so….but I need to lock down the right shifter for the truck. Here’s the shifters I’m considering: B&M Pro Rachet B&M Hi-Tek Street Bandit B&M Magnum Grip Pro Stick B&M Stealth Pro Ratchet TCI Outlaw I'm open to other options. transmission: 4l60E Link to comment Share on other sites More sharing options...
DemoN Posted June 21, 2012 Author Share Posted June 21, 2012 ok. both the pro rachect and the stealth pro rachet are "return to center" shifters. so they dont need alot of throw room. just what you see there. The others all need that full room to move. Link to comment Share on other sites More sharing options...
jwright0291 Posted June 21, 2012 Share Posted June 21, 2012 Link to comment Share on other sites More sharing options...
DemoN Posted June 21, 2012 Author Share Posted June 21, 2012 lmao no. Link to comment Share on other sites More sharing options...
Ralfy Posted June 21, 2012 Share Posted June 21, 2012 Would the console from.a.Denali work?? Link to comment Share on other sites More sharing options...
Team Adam's Posted June 21, 2012 Share Posted June 21, 2012 I like the look of that B&M stealth, but with your tank, wheels, etc it might make more sense to bring some raw metal inside with the street bandit. Link to comment Share on other sites More sharing options...
J Tegeler Posted June 21, 2012 Share Posted June 21, 2012 My vote goes on the B&M Magnum Grip Pro Stick Link to comment Share on other sites More sharing options...
JBlack151 Posted June 21, 2012 Share Posted June 21, 2012 My vote is for the B&M Magnum Grip Pro Stick Link to comment Share on other sites More sharing options...
DemoN Posted June 22, 2012 Author Share Posted June 22, 2012 I like the look of that B&M stealth, but with your tank, wheels, etc it might make more sense to bring some raw metal inside with the street bandit. You and i are thinking along the same lines. if i go Stealth (which that or the pro rachect is what i'm currently leaning towards) then i will make sure the decorative top of the console will be SS plating so there will still be alot of polisted metal inside. There is also the option of the stealth with the magnum pro stick grip option i think. *looking!* Link to comment Share on other sites More sharing options...
DemoN Posted June 22, 2012 Author Share Posted June 22, 2012 Would the console from.a.Denali work?? it would...but i want to custom build a console Link to comment Share on other sites More sharing options...
DemoN Posted June 22, 2012 Author Share Posted June 22, 2012 oh...FYI: the base will not be seen...and neither will any of the gear indicator. so, all you'll see of this in the truck is the shaft, handle, and reverse lockout. Link to comment Share on other sites More sharing options...
THE Mook Posted June 22, 2012 Share Posted June 22, 2012 pistola pistola! Link to comment Share on other sites More sharing options...
DemoN Posted June 22, 2012 Author Share Posted June 22, 2012 yes: [ame=http://www.youtube.com/watch?v=G4RkOGp9qSk]B&M shifter, ratchet shifter, automatic shifter - YouTube[/ame] Link to comment Share on other sites More sharing options...
Ralfy Posted June 22, 2012 Share Posted June 22, 2012 it would...but i want to custom build a console i see, was just offering up a suggestion what about installing a TKO 6 speed?? haha i was watching a few videos on the ratchet shifter and it seems like if your not paying attention and forget to "shift" the trans, you could cause internal damage or an over heat in the transmission. is there any kind of fail safe for these?? like a rev limiter or something? Link to comment Share on other sites More sharing options...
DemoN Posted June 25, 2012 Author Share Posted June 25, 2012 i see, was just offering up a suggestion what about installing a TKO 6 speed?? haha i was watching a few videos on the ratchet shifter and it seems like if your not paying attention and forget to "shift" the trans, you could cause internal damage or an over heat in the transmission. is there any kind of fail safe for these?? like a rev limiter or something? Well, you only operate it as a ratchet when you want. any other time i can shift it into OD and it'll shift as normal. it's just like your standard automatic gear shifter....but it simply allows you to "hammer" your own shifting without sweating the chance of gear missing. Link to comment Share on other sites More sharing options...
Faze Posted June 25, 2012 Share Posted June 25, 2012 Tci outlaw Link to comment Share on other sites More sharing options...
Ralfy Posted June 27, 2012 Share Posted June 27, 2012 Well, you only operate it as a ratchet when you want. any other time i can shift it into OD and it'll shift as normal. it's just like your standard automatic gear shifter....but it simply allows you to "hammer" your own shifting without sweating the chance of gear missing. Learn something new everyday? Hey are you signed up on performance trucks dot net?? Lots of good info there Link to comment Share on other sites More sharing options...
