C5 Corvette
Jlaw1313
Has anybody used the new Paint Correcting Polish on a C5? Foam or microfiber pads?
I have a used my PC with the SSHR,SHR and foam pads in the past. While the results are good, it takes a long time.
Will a Flex help as well with the new system?
10 answers to this question
Yea, it took FOREVER on my c5z with a G110v2 (porter cable equivalent) and the old polishes on foam pads.
With a Flex, Microfiber pads, and the new polishes it should clear those swirls right up.
Thanks all for your feedback!
Just ordered the orange microfiber pads to use with Paint Correcting Polish. I'll give them a try with my PC before springing for a Flex.
Would Fine Machine Polish/White Foam Pad be an acceptable method to finish?
Edited by Jlaw1313
That will work too.  PFP has a longer work time, but this time of year that is not too much of an issue!
Thanks for the tip.
Take your time with this job. I used to have a C5 and let me tell you, the clear on those is hard. It will likely take a number of passes to get the results you want, but it's worth the effort.
Post of your pics when you get 'er done, too! :cheers:
Got it!
