Jlaw1313 Posted January 26, 2014 Share Posted January 26, 2014 Has anybody used the new Paint Correcting Polish on a C5? Foam or microfiber pads? I have a used my PC with the SSHR,SHR and foam pads in the past. While the results are good, it takes a long time. Will a Flex help as well with the new system? Link to comment Share on other sites More sharing options...
0 JHL88 Posted January 26, 2014 Share Posted January 26, 2014 Yea, it took FOREVER on my c5z with a G110v2 (porter cable equivalent) and the old polishes on foam pads. With a Flex, Microfiber pads, and the new polishes it should clear those swirls right up. Link to comment Share on other sites More sharing options...
0 Holder Posted January 26, 2014 Share Posted January 26, 2014 (edited) Yep, you'll get great results with the Flex, MF pads and PCP/PFP. On a C5 I usually work the polisher at a speed 4.5 to get the best results. Edited January 26, 2014 by A_HoderSS Jlaw1313 1 Link to comment Share on other sites More sharing options...
0 Rich Posted January 26, 2014 Share Posted January 26, 2014 Nope. Still do mine by hand. Link to comment Share on other sites More sharing options...
0 mc2hill Posted January 26, 2014 Share Posted January 26, 2014 I have done a C5 with the MF pads & PCP and it worked fine. The MF pads save a lot of time when doing correction. I use PFP and a white foam pad to finish. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted January 26, 2014 Share Posted January 26, 2014 The new MF pads seem to speed up the process with any machine.......they work great with the Cyclo. Link to comment Share on other sites More sharing options...
0 Rich Posted January 27, 2014 Share Posted January 27, 2014 Where are the car pics??? Link to comment Share on other sites More sharing options...
0 Jlaw1313 Posted January 27, 2014 Author Share Posted January 27, 2014 (edited) Thanks all for your feedback! Just ordered the orange microfiber pads to use with Paint Correcting Polish. I'll give them a try with my PC before springing for a Flex. Would Fine Machine Polish/White Foam Pad be an acceptable method to finish? Edited January 27, 2014 by Jlaw1313 Link to comment Share on other sites More sharing options...
0 mc2hill Posted January 27, 2014 Share Posted January 27, 2014 Would Fine Machine Polish/White Foam Pad be an acceptable method to finish? That will work too. PFP has a longer work time, but this time of year that is not too much of an issue! Link to comment Share on other sites More sharing options...
0 Marylander Posted January 27, 2014 Share Posted January 27, 2014 Take your time with this job. I used to have a C5 and let me tell you, the clear on those is hard. It will likely take a number of passes to get the results you want, but it's worth the effort. Post of your pics when you get 'er done, too! Link to comment Share on other sites More sharing options...
0 Jlaw1313 Posted January 27, 2014 Author Share Posted January 27, 2014 That will work too. PFP has a longer work time, but this time of year that is not too much of an issue! Thanks for the tip. Take your time with this job. I used to have a C5 and let me tell you, the clear on those is hard. It will likely take a number of passes to get the results you want, but it's worth the effort. Post of your pics when you get 'er done, too! Got it! Link to comment Share on other sites More sharing options...
Jlaw1313
10 answers to this question
